Mesh has 14 UV maps. How to use with Octane?
pixelsmack
Octane only lets me select 1-3. Is there a way to access the other UV maps in this mesh?
Lewis
It is 3 maps per layer so you could split your model into layers (so it's 3 UVs per layer) if needed OR just merge UVs if you have different materials/surfaces.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
smount1
give them all the same name, unless they're are both linear and subpatch UV's, then you'll need two.
TheMightySpud
If they have 1 surface per UV Map, you could assign them in the LW native surface editor and use the Octane UVMAP Node to use the settings from the LW T colour channel.
Return to “Lightwave 3D”
