Reset ALL light sampling rate to 1
coilbook
Can we have a global button to Reset ALL light sampling rate (texture) to 1
With hundreds of light emitting textures or old light textures imported (each one has its own sampling rate set) and juggling between light sampling priorities among textures it would be nice to have this button.
coilbook
Also please add automatic movable proxy. It's such a pain right now. You uncheck update static geometry and if some moving mesh is not check it'll be stationary. Why cannot the system, detect what moving and auto apply movable proxy.
Hi coilbook,
your requests seems more related to your integrated plugin, than Standalone.
In Standalone there is not the Movable Proxy concept, since it is related to the creation of animated contents, so specifically related to plugins.
About Sample Rate in lights, in Standalone you should need a Lua script for that, while in an integrated plugin it should be easy to filter select all the lights in one go, and easily change the Sample Rate to all of them with a couple of clicks:
ciao Beppe
coilbook
bepeg4d wrote:Hi coilbook,
ciao Beppe
HI, thanks. We also want to reset sampling rate inside emission textures to 1 not just octane lights. Not sure if it's possible
HHbomb
You can try with Zorb tool... I'll see on monday?
