OctaneRender 2020.1 for Houdini Production build 2020.1.5.3
eyeonestudio
Thank you for new update. ;)
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
juanjgon
I've updated this post adding a new 2020.1.5.3 build that includes an option to configure a pause between renderings and avoid a rare issue related to duplicated files. This workaround that was always enabled in the previous versions is now disabled by default.
Gregor.Zimmermann
Hey everyone,
this is the first time I'm using Octane for Houdini.
Unfortunately I get an error message saying - 3448: Fatal error: Segmentation fault
In this case it's 3448, but I've also been getting 13484 and other numbers.
I've already tried upping the tdp settings in regedit, since I read that this can be caused by these settings being set to a too small value.
Would be great to see if there's a solution to this.
juanjgon
Gregor.Zimmermann wrote:Hey everyone,
Sorry, but we are going to need more information to try to know what's the problem.
- When do you get this error, while rendering in the IPR?
- What is your houdini.env config file? It is important that the Houdini and Octane plugin build versions match to avoid problems.
- What are you system specs?
- Do you know if Standalone or other plugins work fine in this system?
Gregor.Zimmermann
Thanks so much for getting back to me that quickly!
I hope, you can help me out based on my answers.
Unfortunately this error comes up after like 1 or 2 mins into running Houdini. Doesn't matter if I work with it or not.
Also it doesn't matter if I open the IPR or not.
My file looks like this:
PATH = "C:\Octane_2020.1.5.3_Houdini_18.5.351_Win64\bin;$PATH"
HOUDINI_PATH = "C:\Octane_2020.1.5.3_Houdini_18.5.351_Win64;&"
HOUDINI_DSO_ERROR = 2
I'm using Houdini 18.5.351 so they should match.
Windows 10 Pro 10.0.19041
Ryzen 3900X
64 GB Ram
3090 + 1080Ti GPU
I have no problem running Octane in Cinema4D. Standalone works as well, but I don't really use this.
juanjgon
Hmm, so do you say that Houdini crashes even if you are not rendering with Octane? This is really weird! I'm not sure if we are facing an Octane or a Houdini bug, to be honest. It could be great to know if you have the same problem while working with Houdini but with the Octane plugin uninstalled (commenting or removing the houdini.env variables).
Sometimes Houdini dumps a debug file to C:\Users\<your user>\AppData\Local\Temp\houdini_temp with the name "crash.xxxxxxxxxxxxxxxxxx_log.txt" ... it could be great to check the latest log file in this folder just after one of these crashes.
Gregor.Zimmermann
Okay, I'm not a hundred percent sure as of now, but I guess I fixed it.
I found a helpful comment on reddit
https://www.reddit.com/r/MSI_Gaming/com ... oblem_fix/
Basically a bug in the audio driver is causing this issue, if I understand this right.
Thanks so much for your fast reply, though!
juanjgon
I've updated this post including a proper plugin build for Houdini 18.5.408.
pxlntwrk
juanjgon wrote:Hi,
Thanks ! ;)
pxlntwrk.net
juanjgon
I've updated the post again to include the OctaneX PR6 for Catalina plugin builds.
Return to “Releases”
