Hi
I am getting constant crashes with very simple scenes. It happens mostly when I am doing something in the node editor.I get a window that says, “Graphic Driver Error. Please check if your graphics driver and OS are up to date.” I have honestly no clue how I can update the graphic driver on mac. Please mind the scene is very simple. I am still learning
Below is the bug report.
My specs:
A. MA OS 10.15.7
B. AMD RADEON RX5700 XT via egpu
C. 8gb ram
D. Don’t know
E. Octane X STUDIO PR3
F. Octane X STUDIO PR3
Thank You for any help
Piotr Janowski
Graphic driver error on Octane X
C. RAM Capacity (i.e. 6 GB)
- octanelog_report.zip
- (109.93 KiB) Downloaded 213 times
iMac (Retina 5K, 27-inch, 2017)
4,2 GHz Quad-Core Intel Core i7
40 GB 2400 MHz DDR4
Radeon RX 5700 XT (external GPU Akitio Node)
40 GB 2400 MHz DDR4
please try with PR4 and report back, thanks.
You can find it by visiting your personal Downloads area:
https://render.otoy.com/account/download_archive.php
ciao Beppe
ciao Beppe
Standalone is not required. But why don't you keep it synced if you need standalone?pjano wrote:Hi!
I found only the PR4 plugin version/. Can I use that with PR3 Standalone?
Thank You
Piotr
Yes, you can open in Standalone PR3, an .orbx file exported from c4doctaneX PR4, but be careful, PR3 does not have a good OSL support, so if you have used some OSL textures in c4doctaneX PR4, you will have issues in Standalone PR3 with that scene.
ciao Beppe
ciao Beppe
Thank You
So I was able to test Pr4 on my setup and I can confirm that working in the node editor is much more stable now but now I am getting random crashes. One even restarted my whole computer.
I am sending You my recent bug reports.
One thing that got me thinking was when You asked if the card is correctly powered. Is it possible that the card is recognized and working but still could be not connected in the egpu correctly?
Thank You
Piotr
Thank You
Piotr
- octanelog_report2.zip
- (116.76 KiB) Downloaded 208 times
- this is the one where the computer crashed.
- (121.13 KiB) Downloaded 235 times
40 GB 2400 MHz DDR4
40 GB 2400 MHz DDR4
great to hear that you have more stability in node editor now, it means that the eGPU is working correctly.
In both logs, it is the AMD Radeon driver that is crashing.
The devs have identified and fixed a couple of issues for Navi GPUs, and will be available in next OctaneX PR version... stay tuned.
ciao Beppe
ciao Beppe
