render kernel fail - path tracing
Moderator: JimStar
baxley
This is happening quite often, occasionally get a 'render kernel fail' other times it shows no errors.
REnderer-
-octane... moving camera around... suddenly stops updating, can still move model but it shows wireframe moving with rendered image frozen (it's not lagging or updating, it just stops).
After i click renderer - viewport 2.0 i can keep working but to get octane to work again I have to close/reopen maya.
Generally using path tracing.
I've tried adding a new kernel without closing maya but no luck.
This happens in heavy and light scenes.
Please advise.
itsallgoode9
you might be able to force it to start again if you switch the frame cache from 0 to 1 then back to zero. That fixes other similar issues so maybe it'll fix yours as well.
baxley
itsallgoode9 wrote:you might be able to force it to start again if you switch the frame cache from 0 to 1 then back to zero. That fixes other similar issues so maybe it'll fix yours as well.
No luck, thanks though
itsallgoode9
have you checked the render engine log in verbose mode? sometimes that can give you some insight
Return to “Autodesk Maya”
