OctaneRender 2020 for DAZ Studio [TEST and STABLE][OBSOLETE]
Moderator: BK
Tugpsx
Thanks! so at this point Octane is considered working properly again. The hang-ups sometimes caused the configuration changes not to save correctly. They are saving now.
Tugpsx
valzheimer
Tugpsx wrote:Can confirm that with new driver and version of Daz Studio 4.14 and Octane. the application will stay in memory for 2.5-3 min after you exit. I tried several tests and within 3 min of closing the application the app exits in task manager.
Ironically enough after the update even with Octane plugin disabled now my DS no longer wants to close properly, not after few minutes or after several hours.
Tugpsx
You may have to use the desktop trick
Simply add the following to a batch file that sits on you desktop to quickly kill the DAZ task
taskkill /F /IM DAZStudio.exe
OneManVN
Does anyone have any news on the next Octane for DAZ build? It would be nice to have that denoiser working... I'm stuck with a 20 series card where my second 3090 should be :(
OneManVN wrote:Does anyone have any news on the next Octane for DAZ build? It would be nice to have that denoiser working... I'm stuck with a 20 series card where my second 3090 should be :(
The Octane 2020.2 version of the plugin will not be released until the Octane 2020.2 final build is release (ie. the plugin won't be available for Octane 2020.2 RC builds).
OneManVN
The Octane 2020.2 version of the plugin will not be released until the Octane 2020.2 final build is released (ie. the plugin won't be available for Octane 2020.2 RC builds).
I figured as much, but I was looking for some sort of an eta. In other words, any chance we are getting it before 2021? Also, thanks for the reply.
I don't know what OTOY's target date for the final release of Octane 2020.2 is, sorry.
Witpapier
IS it Just me, or can I only use one GPU at a time?
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
Banti
Witpapier wrote:IS it Just me, or can I only use one GPU at a time?
Have you checked if all your GPUs are active under the systems tab? Are you using the studio version of the plugin?
Return to “DAZ Studio”
