Hair material specular
Moderator: JimStar
visionmaster2
Thank your for the file !
it's really close to what i need :)
i can see that you changed the the roughness and the Azimuthal roughness.
Did you changed something else ?
when i put your material to my scene (with the light from the ForM2 file) the hair are still to white.
thank you
M.°
BK
visionmaster2 wrote:Thank your for the file !
thank you
M.°
Hello M,
Thank you again!! I guess both the Roughness value was low in the previous samples.
We did not change apart from that.
Is it possible to PM the Hair and the light only for us to look again?
Cheers
Kind Regards
bk3d
visionmaster2
Thank you for your Help !
the file must be in your Box now.
Merci beaucoup :)
M°
BK
visionmaster2 wrote:Thank you for your Help !
Merci beaucoup :)
M°
Hi M,
Thank you so much.
cheers
Kind Regards
bk3d
visionmaster2
Thank's to you and the devs !
M.°
Return to “Autodesk Maya”
