Inside material ?
roinigo
I try to have a material inside a surface (cube) but i can't get how to do it.
Here some captures.
Could you help me to solve this please ?
ASUS PRIME X470-PRO
AMD Ryzen 7 2700X 8 cores
Noctua NH-U12S SE-AM4
G.SKILL FLARE X SERIES 64 GO (4X 16 GO) DDR4 2933 MHZ CL16
RTX 2080 Ti + GTX 980
Seasonic PRIME 1000 W Gold
Fractal Design Define R6
galleon27
Looks like you are using an Emission material and your polygon normals, the ones inside the cube, are probably facing the wrong direction.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
roinigo
How can i change polygon facing direction, please ?
ASUS PRIME X470-PRO
pxlntwrk
hi,
polygon selected > right click > reverse normal
pxlntwrk.net
frankmci
Also, an easy way to see what's up with surface normals is using either
panel menu/Options/Polygon Normals, and select the faces in question
or render with
Octane Info Channels Kernel/Shading Normals
