Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
Kalua
jayroth2020 wrote:Do you see the same result in Standalone?
Yes. The very same behavior.
Exactly same behavior as described in C4D
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
One thing is like that's not a plugin issue, especially if you see same results in standalone. Please send a sample scene with details to support team.
Kalua
Sent as PM.
Antoncromas
Hello,
Render is getting stuck on denoiser which doesnt seem to be working after a system update and I just started using rtx 3090.
I reinstalled windows and all apps and the problem still there.
Am I missing a package from nvidia or something? Any work arounds?
Kalua
Antoncromas wrote:Hello,
30XX Sseries are using denoiser untill now with 2020.2 XB4.
Get it and have a try.
Antoncromas
Thank you.
Hmmm I cant seem to find 2020.2 where is the release forum for 2020.2 for c4d?
Kalua
Thank you.
Standalone only for now. It is still XB-4. I don't think there will be a C4D build until the first RC comes around.
Antoncromas
I see, then it doesnt really do anything for me since I dont use stand alone. =(
Antoncromas wrote:I see, then it doesnt really do anything for me since I dont use stand alone. =(
Not properly, you can prepare your scene with 2020.1.5-R4, then export it in .orbx animated format to Standalone 2020.2-XB4, and render your sequence from there, with AI Denoiser active for Ampere GPUs.
Happy GPU Rendering,
ciao Beppe
Antoncromas
ciao Beppe
Thanks for the suggestion but that's not gonna work for what I do. I work in RT with clients to preview 3D environments on photoshoots. So it's a bit of a problem right now.
Return to “Releases”
