Yes. The very same behavior.jayroth2020 wrote:Do you see the same result in Standalone?
Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
C4D 2025.1.1 Octane 2026.1 v1.8.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Octane User since V1 Beta
One thing is like that's not a plugin issue, especially if you see same results in standalone. Please send a sample scene with details to support team.Kalua wrote:Yes. The very same behavior.jayroth2020 wrote:Do you see the same result in Standalone?
Sent as PM.aoktar wrote:One thing is like that's not a plugin issue, especially if you see same results in standalone. Please send a sample scene with details to support team.Kalua wrote:Yes. The very same behavior.jayroth2020 wrote:Do you see the same result in Standalone?
- Antoncromas
Hello,
Render is getting stuck on denoiser which doesnt seem to be working after a system update and I just started using rtx 3090.
I reinstalled windows and all apps and the problem still there.
Am I missing a package from nvidia or something? Any work arounds?
30XX Sseries are using denoiser untill now with 2020.2 XB4.Antoncromas wrote:Hello,
Get it and have a try.
- Antoncromas
Thank you.Kalua wrote:30XX Sseries are using denoiser untill now with 2020.2 XB4.Antoncromas wrote:Hello,
Hmmm I cant seem to find 2020.2 where is the release forum for 2020.2 for c4d?
Standalone only for now. It is still XB-4. I don't think there will be a C4D build until the first RC comes around.Antoncromas wrote:Thank you.Kalua wrote:30XX Sseries are using denoiser untill now with 2020.2 XB4.Antoncromas wrote:Hello,
- Antoncromas
I see, then it doesnt really do anything for me since I dont use stand alone. =(
Not properly, you can prepare your scene with 2020.1.5-R4, then export it in .orbx animated format to Standalone 2020.2-XB4, and render your sequence from there, with AI Denoiser active for Ampere GPUs.Antoncromas wrote:I see, then it doesnt really do anything for me since I dont use stand alone. =(
Happy GPU Rendering,
ciao Beppe
- Antoncromas
Thanks for the suggestion but that's not gonna work for what I do. I work in RT with clients to preview 3D environments on photoshoots. So it's a bit of a problem right now.bepeg4d wrote:Not properly, you can prepare your scene with 2020.1.5-R4, then export it in .orbx animated format to Standalone 2020.2-XB4, and render your sequence from there, with AI Denoiser active for Ampere GPUs.Antoncromas wrote:I see, then it doesnt really do anything for me since I dont use stand alone. =(
ciao Beppe
