CUDA errors
samsue
paride4331 wrote:Hi samsue,
first: using Nvlink you have tu set on Out of core.
second: keep in mind Nvidia removed 2 x 2 Nvlink support (geforce and quadro) so it doesn't work on your slave.
In your case, you would unplug the second Nvlink, then set Out-of-core during slave setup.
You will be able to use Nvlink only using 2 GPUs master + 2 GPUs slave; you cannot use Nvlink using all of 6 GPUs.
If you really want to use Nvlink, instead of out-of-core only, you shoud have a secondary 2x GPU slave.
I hope it helps.
Rgards
I was reviewing some topics, I decided to test in my Workstation, SLI to have vRam pool with nvlink ( 2x 2080 Ti 11 gb so 22gb vram )
1. Is the vraym pool working?
2. You said that if I'm using nvlink, I have to activate the out of core, but so Octane uses cpu ram
paride4331
I hope it helps.
Rgards
Hello samsue,
don't forget Nvlink works with geometryes only, the textures will go to Ram.
samsue
any idea? on my workstation works fine, but the server, crashs always
samsue
can these problems be related to a bad video card?
bad video card
Return to “Autodesk 3Ds Max”
