In Light Tag, activate "use primitives" ?
mtb_mike
I have seen this tip a few times...
In Light Tag, activate "use primitives" parameter and use AI lights in kernel
What is "use primitives"? I cant find it in the documentation. By the way, Cinema's docs are at 2019.1. Is there a more up to date version somewhere?
thanks
iMac 4.2 GHz 40GB RAM | OS 10.13.6 C4D r20 Octane 4.02.1-R3 | Akitio Node with GTX 1080 Ti | Nvidia driver 387.10.10.10.40.122 | Cuda 410.130
Windows 10 Network Render System with Four GTX 970s, Same Octane Version
jayroth2020
We are getting ready to release the next documentation update for Cinema. In the meantime, the "Use Primitives" option is used in combination with the AI Light option found in the Settings and activates the Spectron feature. Spectron resolves light more quickly and with less noise. It is currently limited to plane and spherical light shapes, which you set in the Details panel of the Octane area light.
mtb_mike
jayroth2020
You're welcome!
