Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
Kalua
aoktar wrote:
Kalua wrote:Aperture Rotation is not working with Universal camera.
Cheers,
you can check exported structure and values
It means it's a core BUG then. The aperture shape is clearly not rotating. It does, however, rotate with normal thinleans camera.
PS.: In Standalone bokeh rotation works just fine with Universal Camera.
C4D 2025.4 Octane 2025.4 v1.7.2, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
thanulee
Thanks a lot Ahmet for the fast versions and great features. I love the new TAB in node editor and overall 2020 has been the most stable for me so far.
Cheers
mtb_mike
Getting some strange artifacting in the LV with this release. Viewport rendering works ok. Forgot to try an actual render. Downgraded to 2020.1.4 and back to normal. Mac High Serria, S22, 1080ti, akitio node.
iMac 4.2 GHz 40GB RAM | OS 10.13.6 C4D r20 Octane 4.02.1-R3 | Akitio Node with GTX 1080 Ti | Nvidia driver 387.10.10.10.40.122 | Cuda 410.130
Windows 10 Network Render System with Four GTX 970s, Same Octane Version
mtb_mike wrote:Getting some strange artifacting in the LV with this release. Viewport rendering works ok. Forgot to try an actual render. Downgraded to 2020.1.4 and back to normal. Mac High Serria, S22, 1080ti, akitio node.
Maybe about osx version and resolution. Try with different desktop resolution for test
dynaraton
Also getting the broken render like mtb_mike showed above in Live Viewer. Same right side and bottom artifacts. Works fine when rendering to picture viewer.
I have the latest 452.06 Nvidia Studio Driver and the latest C4D S22.123 installed.
Went back to previous version 2020.1.4.
UPDATE: I have to stretch the LV window really big horizontally and vertically to have the artifacts fade away from my render. Never happened in previous versions.[/b][/b]
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (2) Nvidia RTX TITANs w/ NvLink : Win11 Pro : Latest Cinema4D
mtb_mike
[/quote]Maybe about osx version and resolution. Try with different desktop resolution for test[/quote]
osx version is 10.13.6. It does work fine at full pixel resolution of 5120x2880. All other resolutions have the strange screen redraw.
Wish I could work at 5k. Talk about screen real estate!
and external 1080ti
dynaraton wrote:Also getting the broken render like mtb_mike showed above in Live Viewer. Same right side and bottom artifacts. Works fine when rendering to picture viewer.
What's screen resolution? Using a desktop scaling?
dynaraton
Under my Windows 10 display settings it shows:
Scaling - 150% (recommended)
Display Resolution - 3840 x 2160 (recommended)
I am back on 2020.1.4 and everything is fine as was in previous versions. I didn't make any changes to my scaling or resolution.
Thanks for the quick response.
@dynaration, it's probably about using %150 scaling. This version has canvas scaling addon as a difference against previous version. Try %100 for feedback.
wrapthereal66
thanks for the update guys ! i just wanted to know when the new graphic cards from nvidia ( 3080) will be added into the c4d plugin version of octane ? i work with nvidia and i have a 3080, that would be really cool to have a release for that ! i need to make test ! :D
thanks you very much!
Return to “Releases”
