OSL Shader code knowledge?
TheMightySpud
Does anyone have any knowledge of OSL Shader coding?
I've found a free script to add Interiors to windows which looks really good (replicates the effects from the old vRoom plugin).
Problem is the guy didn't have access to LW when he wrote it and kinda guessed about the mapping (Was written back in 2017).
I've tried poking around the code, but have no idea how LW deals with it's mapping in terms of OSL.
Would be extremely grateful if anyone would be able to take a look at it and maybe fix it? (I think other people may be quite grateful too)
I've included the shader script and 'template' image along with an IPR render of how it's currently (not) working.
(would also be very handy to change the 'string' input to a texture image :) if that's possible)
TheMightySpud
#include <stdosl.h>
shader jiWindowBox_LWOctane(
	string input_tex = "t:/installs/genericLivingRoom03.exr",
        int textureFlip = 0 ,
        int textureFlop = 0 ,
        float roomDepth = 1 [[ float min = 0.1, float max = 100 ]],
        float widthOverscan = 0 [[ float min = 0.0, float max = 0.9 ]],
        float heightOverscan = 0 [[ float min = 0.0, float max = 0.9 ]],
        int enableMidground = 0,
        float midgroundDepth = 0.5 [[ float min = 0.05, float max = 99 ]],
        float midgroundOffsetX = 0,
        float midgroundOffsetY = 0,
        int enableCurtains = 0,
        output color result = 0.0
    //user controls remapping
    float roomDepthMult = clamp(roomDepth,0.1,100);
    float heightOverscanMult = 1 - clamp(heightOverscan,0,0.9);
    float widthOverscanMult = 1 - clamp(widthOverscan,0,0.9);
    float midgroundDepthMult = clamp(midgroundDepth,0.05,roomDepthMult-0.01);
    float midgroundOffY = midgroundOffsetY * (textureFlip*2-1) * 0.1;
    float midgroundOffX = midgroundOffsetX * (textureFlop*2-1) * 0.1;
    //global variables & remapping
    vector objI = transform("object", -I);
    objI = vector(-objI[0],-objI[1],-objI[2]) * color(widthOverscanMult, heightOverscanMult, 1);		//reorder to match UV for Y up axis
    color objPOrig = (color(u,v,0.5) * 2 - 1) * 0.5 + 0.5;							//for curtains
    color objP = (color(u,v,0.5) * 2 - 1) * color(widthOverscanMult, heightOverscanMult, 1)  * 0.5 + 0.5; 	//UV seems to be the better approach
    //bases for width/height/depth
    vector sections = step(0, objI);
    color baseDepth = (objP-sections)/(-objI * roomDepthMult);
    color mgDepth = (objP-sections)/(-objI * midgroundDepthMult);
    color baseBack = (objP-sections)/(-objI);
    color baseWidth = baseDepth * roomDepthMult;
    //depth and width ramps
    color baseDepthX = (baseDepth[1]*objI+objP + 1);
    color baseDepthY = (baseDepth[0]*objI+objP + 1);
    color baseWidthX = (baseWidth[1]*objI+objP + 1);
    color baseWidthY = (baseWidth[0]*objI+objP + 1);
    float horizU = baseDepthY[2] - 0.5;
    float vertU = baseWidthX[0] - 1;
    float horizV = baseWidthY[1] - 1;
    float vertV = baseDepthX[2] - 0.5;
    //convert ramps to UV/ST... WIP - not very efficient
    float sideWallsMask = step(0,horizU) * step(0,1-max(horizV, 1-horizV));
    color sideWallsUV = color(horizU, horizV, 0) / 3;
    color rWallUV = (sideWallsUV + color(2.0/3.0, 1.0/3.0, 0)) * sideWallsMask * sections[0];
    color lWallUV = (sideWallsUV + color(0.0, 1.0/3.0, 0)) * sideWallsMask * (1-sections[0]);
    lWallUV[0] = (1.0/3.0 - lWallUV[0]) * sideWallsMask * (1-sections[0]);
    float FloorCeilMask = step(0,vertV) * step(0,1-max(vertU, 1-vertU));
    color FloorCeilUV = color(vertU, vertV, 0) / 3;
    color ceilUV = (FloorCeilUV + color(1.0/3.0, 2.0/3.0, 0)) * FloorCeilMask * sections[1];
    color floorUV = (FloorCeilUV + color(1.0/3.0, 0, 0)) * FloorCeilMask * (1-sections[1]);
    floorUV[1] = (1.0/3.0 - floorUV[1]) * FloorCeilMask * (1-sections[1]);
    color backWallUV = ((baseBack[2]*objI + (objP/2)/(roomDepthMult)) * (roomDepthMult*2) / 3 + color(1.0/3.0, 1.0/3.0, 0) ) * (1 - max(step(0,horizU), step(0,vertV)));
    color midgroundUV = (1.0/3.0 - (baseBack[2]*objI + (objP)/(midgroundDepthMult*2)) * (midgroundDepthMult*2) / 3);
    float midgroundMask = step( 0, midgroundUV[1] * 3 * (1-midgroundUV[1]*3) ) * step( 0, midgroundUV[0] * (1.0/3.0-midgroundUV[0]) );
    midgroundUV = (color(midgroundOffX, midgroundOffY, 0) + midgroundUV);
    midgroundUV[1] = (1-midgroundUV[1]) - 2.0/3.0;
    color curtainsUV = objPOrig * color(1.0/3.0, 1.0/3.0, 1);
    curtainsUV[0] = 1.0/3.0 - curtainsUV[0];
    curtainsUV[1] = 2.0/3.0 + curtainsUV[1]; //VRay specific
    color finalUV = ceilUV + floorUV + rWallUV + lWallUV + backWallUV;
    //flipping ctrl
    if (textureFlop < 1){   //VRay specific
        midgroundUV[0] = 1.0/3.0 - midgroundUV[0];
    }else
        finalUV[0] = 1-finalUV[0];
    if (textureFlip > 0){
        finalUV[1] = 1-finalUV[1];
        midgroundUV[1] = 1.0/3.0 - midgroundUV[1]; // VRay specific
        curtainsUV[1] = 1 - curtainsUV[1] + 2.0/3.0; // VRay specific
    color roomRGB = texture(input_tex, finalUV[0], finalUV[1]);
    color finalRGB;
    //midground switch
    if (enableMidground > 0){
        float midgroundA;
        color midgroundRGB = texture(input_tex, midgroundUV[0], midgroundUV[1], "alpha", midgroundA);
        finalRGB = mix(roomRGB,midgroundRGB,midgroundA * midgroundMask); //VRay specific
    else{
        finalRGB = roomRGB;
    //curtains switch
    if (enableCurtains > 0){
        float curtainsA;
        color curtainsRGB = texture(input_tex, curtainsUV[0], curtainsUV[1], "alpha", curtainsA);
        finalRGB = mix(finalRGB,curtainsRGB,curtainsA);
    result = finalRGB;
jiWindowBox_template.zip
(82.21 KiB) Downloaded 263 times
frankmci
I'm coming from C4D, so this may not work at all for you in LW. It's been over a year since I used this, so I'm not really sure what I may have tweaked, if anything, but here's the version of the script that works for me. If you look back a year or two, there was a decent amount of discussion about this script here in the Octane forums.
#include <stdosl.h>
    //flipping ctrl
    }else
    color finalRGB;
    //midground switch
        float midgroundA;
    else{
        finalRGB = roomRGB;
    //curtains switch
        float curtainsA;
    result = finalRGB;
Windowbox OSL C4D
Windowbox OSL C4D
TheMightySpud
Very cool reply thank you.
I will take a look a little later today.
In the meantime, I guess the most useful thing would be an idea of where in the code the different 'tiles' of the texture are positioned/rotated etc. as that seems to be where the script falls down inside of LW (guessing because LW deals with those things differently).
I've tried dissecting the code, but coming up blank. :-/
TheMightySpud
TheMightySpud
Okay, so this is really weird.....
I found this tutorial digging around the older posts about OSL.
https://vimeo.com/303298454
Weird thing is, it uses the exact script that I posted and it works fine, so I am very very confused.
Has something changed in the way the OSL node reads/parses things?
TheMightySpud
TheMightySpud
Even more bizarre-ness going on with OSL.
The room shader now works. Was curious if the rotation of the plane had any bearing on the results. So so in modeller, I rotated it 180 degrees, all went even more screwy.....rotated it another 180 degrees and it now it works fine. wtf? lol.
Now trying to get the tiled image shader to work.....currently not doing a danged thing. lol.
TheMightySpud
frankmci
TheMightySpud wrote:Even more bizarre-ness going on with OSL.
Oh, right, I forgot about that weirdness. Yes, the orientation of the geometry matters in a strange way, based on global coordinates. I could rotate an object and have the material stick properly, but the initial texture projection coordinates of the desired face needed to be on the Neg Z. I'm afraid I never dug into it enough to figure it out, since I found a work-around (create all windows facing -Z, then rotate into proper position) and had a deadline to meet.
Try applying it to a simple cube to see some real wackiness. If it's like in C4D, it will be clear that it only works properly on the -Z face. I'm guessing that to work properly, this script needs a seperate Image Texture node input, and then that node needs a Projection node with, "OSL Projection," or "OSL Delayed."
TheMightySpud
Very baffled about the projection direction tbh, as it's the same as it originally was, just with a 360 rotation. So very very stupid. lol.
baltort
I hacked the vRoom C4D OSL to work in Lightwave a couple of years ago. Does this do what you need?:
viewtopic.php?f=36&t=66988
I think there's an OSL camera to bake rooms in that thread as well, but I'm struggling to remember how it works...
Shout if you need anything,
James.
Return to “Lightwave 3D”
