Realflow fluid motion blur in 3dsmax
maneality
What's the workflow to enable Motion Blur on fluids - Realflow BIN Mesh objects in 3dsmax. Is it even possible?
I can't find Motion Blur - VERTEX SPEED option anywhere (like we have in Cinema).
BTW. Why the manual for 3dsmax is so old, there is bunch of things missing there, can't believe its so hard to update it? :?:
https://docs.otoy.com/3DSMaxH/3DSMaxPluginManual.htm
paride4331
maneality wrote:What's the workflow to enable Motion Blur on fluids - Realflow BIN Mesh objects in 3dsmax. Is it even possible?
Hi maneality,
are you using Realflow for 3dsMax or SA?
maneality
Standalone, then imported the fluid as a BIN mesh object (RFMeshLoader)
paride4331
Hi maneality,
motion blur should work fine using Realflow for 3dsMax. As I know, in C4D is the same thing, mb works using the plugin, not importing a BIN mesh object. Isn't it?
maneality
I'm using RF Connect to import BIN mesh object sequence (in both Max and Cinema is the same, we load BIN objects);
Now, in Cinema we have a Vertex speed motion blur type which uses velocity channel from RF to blur the liquids
Similar to here, just with using imported geometry, not RF plugin inside cinema:
http://www.aoktar.com/octane/OCTANE%20H ... nBlur.html
But in Max I can't find the same settings so I'm wondering if it is a different workflow or we can't use velocity channel for the blur in 3dsmax?
maneality
Check here, I think everything is set as it should be but fluid isn't getting any motion blur.
paride4331
maneality wrote:Check here, I think everything is set as it should be but fluid isn't getting any motion blur.
Hi maneality,
could you share your .max scene in order to figure out (in pm if you want).
maneality
Hi maneality,
Sent! :)
maneality
Hey @paride4331 any solution to this?
paride4331
Hi maneality,
it seems no velocity channel available from the object's mesh, could you confirm you added it or could you try to add it?
Return to “Autodesk 3Ds Max”
