Cinema4D version 2020.1.4 (Obsolete stable) 23.07.2020
thanulee
Texture displacement problem in LV is still here unfortunately! doesnt render at all a scene that i have here with displacement plugged
See here: https://www.dropbox.com/s/9bb0xh8c0jncx ... .webm?dl=0
Kalua
thanulee wrote:Hi,
Displacemente works flawlessly for me. Maybe you have a mapping issue?
Have you tried <<Texture displacemente type>> ?
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
thanulee wrote:Hi
Octane object tag "hair" disappears in various occassions.
One of em see below. While inside a cloner, the option is not avail while it renders correct.
https://www.dropbox.com/s/wxv2mfiz9lmvn ... .webm?dl=0
Cheers
I cannot reproduce it! Could you please save the scene and send me?
thanulee
I PMed u the scene file. Cheers
thanulee
A little feedback regarding the node editor TAB function.
The expected behavior is when i type for example "i" and give me "image texture" "invert", the arrow keys work reverse. I would expect it to work with the order i see things in the menu. Now i can only press down arrow or something. Idk if I describe it correct hehe. Thanks a lot
thanulee
Also when i drag something without connecting it, it gives me the dropdown which kinda lags a bit and sometimes stuck the editor here and confuses me.
Can this specific function turned off/on by the user and only use TAB when needed?
thanulee wrote:A little feedback regarding the node editor TAB function.
try sort icon. In default case it increases the index of suggestions.
thanulee
Hi, I cant see the octane object tag in the node editor. I have a tfd container, i select tag and nothing happens. Is that the case there too?
thanulee wrote:Hi, I cant see the octane object tag in the node editor. I have a tfd container, i select tag and nothing happens. Is that the case there too?
try this button
Terryvfx
I think this is a bug, the smoothing normals (phong tag) breaks if use Random Walk on a mesh.
Return to “Releases”
