Cinema4D version 2020.1.4 (Obsolete stable) 23.07.2020
Hi all,
This is the Cinema 4D plugin with latest production ready version 2020.1.2 SDK. Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1.4.
Make sure to use a NVIDIA Studio driver with version at least 435.80 for Windows or 435.12 for Linux to enable support for RTX hardware acceleration. There are no OSX drivers that currently support RTX.
New functionality in node editor
New intuitive workflow for nodes
How to make great looking, fast and fully procedural large clouds in five minutes.
C4D noises(osl implementation) in action, recorded in early stage of development
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1.4 plugin
- Drag&drop support for VDBs as you can do for ORBX/images to Live Viewer
- Several fixes for small issues on node boxes
- Fixed back to behavior: Auto activate denoising when any of denoiser pass is activated for PV rendering
- Improvement for vdb file handling and sequence detect
- Native S22 builds, don't forget to remove other plugin dlls
Plugin related bugfixes from the 2020.1.4 CORE
- Fixed issue causing Octane to not to start on machines using older CPUs without AVX instruction set support.
- Fixed issue causing OSX slaves to deactivate their license even if there are other instances of standalone or plugins currently running on that machine.
- Fixed triplanar projection in OSL when used as emission texture distribution.
- Fixed issue causing displacement nodes not working with layered material nodes.
- Fixed a crash on Windows 7 when upsampling was enabled.
- Fixed issue causing hair primitives and geometry using texture displacement to temporarily disappear after scene some scene changes.
WINDOWS ENTERPRISE BUILD (R15-22)
https://render.otoy.com/customerdownloa ... .4_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-22)
OSX ENTERPRISE BUILD (R15-22)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-22)
R15 resources(just for R15 users)
R15-res.rar
(16.41 MiB) Downloaded 332 times
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
thanulee
Thanks Ahmet ur so fast :)
thanulee wrote:Thanks Ahmet ur so fast :)
Thanks!
handsomeninja
Awesome, thanks Ahmet! I'm switching from Octane 2019... the drag and drop to live viewer you mentioned, does it automatically import and create a VDB loader?
handsomeninja wrote:Awesome, thanks Ahmet! I'm switching from Octane 2019... the drag and drop to live viewer you mentioned, does it automatically import and create a VDB loader?
yes it does, but just works for windows apparently
BCres
Yes, thank you, Ahmet!
I can already confirm that the S22 dll fixes the problem with the LV restarting renders whenever you would move your mouse across the C4D viewport or really any part of the C4D workspace. That was the main reason I had to move back to R21.
thanulee
Wait, so I can drag n drop VDB in LV? how cool!
thanulee wrote:Wait, so I can drag n drop VDB in LV? how cool!
yes, you can drag&drop to LV any VDB/ORBX or images. Droping VDB that will create a VDB object and detect/assign sequence start/end/digits values too!
BCres wrote:Yes, thank you, Ahmet!
Great, thanks for your feedback!
james_conkle
I got excited to see this! Working well on my system so far :) Thanks for the hard work :)
Also - thanks for your website Aoktar - I find myself visiting http://www.aoktar.com a lot :cry:
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
