I still get the same crash i have no clue what they did i did not touch anything on my system at all and then i started to get the crash so its on otoy's end something changed and i cant use the new 2020 builds at all anymore, and i have changed nothing with my system or daz over that period of time from working to crashing.face_off wrote:I have updated the installers at the top of this thread with:
2020.1.4.55
- Compiled with Octane 2020.1.4
OctaneRender 2020 for DAZ Studio [TEST and STABLE][OBSOLETE]
Moderator: BK
- Hun73rdk_1
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
Thanks for the crash report. I have forwarded it to OTOY.I still get the same crash i have no clue what they did i did not touch anything on my system at all and then i started to get the crash so its on otoy's end something changed and i cant use the new 2020 builds at all anymore, and i have changed nothing with my system or daz over that period of time from working to crashing.
- Hun73rdk_1
Also when installing the plugin normally there is a activation window staying up after install that does not happen for me on all the 2020 versions of the octane installer.face_off wrote:Thanks for the crash report. I have forwarded it to OTOY.I still get the same crash i have no clue what they did i did not touch anything on my system at all and then i started to get the crash so its on otoy's end something changed and i cant use the new 2020 builds at all anymore, and i have changed nothing with my system or daz over that period of time from working to crashing.
Hope that it is solved soon.
I just downloaded OctaneRender_for_DazStudio_2020_1_4_55_STUDIO.exe and ran it, and it popped the Activation Manager open for me with the Activation button enabled so that I could see my activation status. Is this not happening for you?Hun73rdk_1 wrote:Also when installing the plugin normally there is a activation window staying up after install that does not happen for me on all the 2020 versions of the octane installer.face_off wrote:Thanks for the crash report. I have forwarded it to OTOY.I still get the same crash i have no clue what they did i did not touch anything on my system at all and then i started to get the crash so its on otoy's end something changed and i cant use the new 2020 builds at all anymore, and i have changed nothing with my system or daz over that period of time from working to crashing.
Pal
- Hun73rdk_1
Nope only for the latest 2019 version it did before with the 2020 versions but after that week off i had and came back to a broken 2020 version the activation window just shows is self for a fraction of a sec when installing and then gone again.
i have no clue whats going on, i left a working octane and came back to a broken one and have not been able to get 2020 versions to work at all.
What is the filename of the installer you are using please?Hun73rdk_1 wrote:Nope only for the latest 2019 version it did before with the 2020 versions but after that week off i had and came back to a broken 2020 version the activation window just shows is self for a fraction of a sec when installing and then gone again.
- Hun73rdk_1
I have all these i have been trying with
Have even been trying to redownload them all and try again and only OctaneRender_for_DazStudio_2019_1_4_46_STUDIO works now
Thanks for your thoughts. Can you please share some renders of before and after of characters in DAZ Studio that you have successfully rendered in Octane for DAZ Studio to match the Iray character skin renders?Banti wrote:1)solomon wrote:Hi Paul, thanks for the great work on the Octane plugin for DAZ Studio.
I have a quick question, is it possible to have a one to one texture look and feel for the character shaders in Iray? Octane tries to convert the Iray materials but when compared, it looks like there is something lacking. Is there a setting we might be missing? or this is what we can expect for the characters to look like after the default conversion?
The auto-conversion will usually not give you the results you want. Especially with skin materials, you almost always have to adjust the bump strenght (usually 0.05-0.15 are good values) as well as the specular roughness (0.2-0.5 are the usual values). Another big thing to keep in mind is the lighting. Octane cannot convert Iray lights, but you can use HDRIs and emissive geometry. The daylight light you use in your pictures makes characters look flat more often than not. Try to use HDRIs and emissive planes.
2)
Looking at your characters eyes, it seems there are some artifacts. Set the ray-epsilon value in the render settings to its minimum value to prevent this.
3)
Make sure that the Surface Material Filter (in the preferences tab) is empty. By default, i think cornea and eylashes are filtered out and not rendered. I attached a picture to show you what it should look like
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.solomonjagwe.com | http://www.nkozaandnankya.com
Do you have the latest NVidia drivers installed? Does Octane Standalone 2020.1.4 render on that PC?Have even been trying to redownload them all and try again and only OctaneRender_for_DazStudio_2019_1_4_46_STUDIO works now
- Hun73rdk_1
I found version 2020.1.3 and it crashed on startface_off wrote:Do you have the latest NVidia drivers installed? Does Octane Standalone 2020.1.4 render on that PC?Have even been trying to redownload them all and try again and only OctaneRender_for_DazStudio_2019_1_4_46_STUDIO works now
i have no clue what is going on.
all my problems came after Octane X
don't use to much time on it if i am the only one then i will just go back to iray or older version of octane
- Capture4.JPG (27.48 KiB) Viewed 4554 times
