Is anyone aware of an OSL texture in Octane that will distort its input image with noise? I'm looking for something similar to C4D's native Distort Effect.
I found this post describing how to do use noise to distort in OSL, but it is for Blender and not using an input image/texture:
https://blender.stackexchange.com/quest ... ion-effect
Thank you!
OSL Distort Texture?
we are working on just such a thing for 2020.2
Here is an OSL shader by Rohan Dalvi that does that. Just create a OSL Projection node and load the script. Make sure your object has uvs.
- uv distort2.zip
- (322 Bytes) Downloaded 397 times
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
- blastframe
That's really exciting, Jules, thank you!Goldorak wrote:we are working on just such a thing for 2020.2
- blastframe
Thank you @galleon27!! I will give this a trygalleon27 wrote:Here is an OSL shader by Rohan Dalvi that does that. Just create a OSL Projection node and load the script. Make sure your object has uvs.
from 2021.1 there is a new Distorted Mesh UV projection mode, no need to use OSL: ciao,
Beppe
Beppe
