Random texture tiling
lcetina
Is it possible to achieve this or at least any similar effect of randomizing/rotating tiles?
https://blogs.unity3d.com/2019/02/14/pr ... -in-unity/
nejck
Chaos radnomization mapping. I suggest taking a look at the latest GTC talk for more info about it - https://developer.nvidia.com/gtc/2020/video/s22153
tldr: As it seems it is in development as we speak :)
Sorry, I can find only the 3ds Max discussion, but please have a look at this texture_tiling.osl script here:
viewtopic.php?f=27&t=65762&hilit=texture_tiling.osl
ciao Beppe
lcetina
Thank you both for replies.
OSL looks great, I've never used it before and I'll give it a try.
Jengo_1
So....No way to do this in C4D? How can I texture a simple wall then? I can't scale up the texture cuz it looks bad, and without doing it it looks tiled...
Or will this OSL code work on C4D octane textures too? Thanks!
Let me know this helps or not
textiler.rar
(2.57 MiB) Downloaded 442 times
Another one
Jengo_1
This looks promising! Will test out asap and let you know
Jengo_1
Hey so I'm struggeling with the second post - when I setup a Projection node with OSLProjection, it won't give me options to add parameters, only the code. Also, I copied the code in, letter by letter, checked 10 times that its identical, but still gives me a syntax error on line 7 (the float ox one).
What am I doing wrong? Any chacne to get the project file? But generally would also like to know how to add parameters to the OSL part.
Thanks Aoktar!
Attached the project! Osl parameters need to be set as how much tiles have in texture for best results. Enjoy it!
textiler.rar
(4.09 MiB) Downloaded 746 times
