Thanx killaD!!!
MAX2Octane exporter for max 2010+
hi kilad, i can´t copy the listener because when this message from octane happens crash 3ds max also...
ITS WORKING WITH THIS LAST VERSION!!!!, LOVE YA KILAD!!!! YOU RULEZZ!!
intel core i7-4960x 3.60 ghz
32 gb ram
win 7 64 bit
1x nvidia geforce gtx 780
1x nvidia geforce GTX TITAN
32 gb ram
win 7 64 bit
- 1cstrasser
Maybe i'm just blonde or something, but i just started using Octane, and my desired path is revit/max/octane...but Ive been having trouble getting materials into octane from that path. I was exporting from revit as an .obj but now I just downloaded the max exporter and i am to extract to "root" folder. (this is the blonde question) where is the root folder....c:/programfiles(x86)/autodesk/3dsmax2011 then where from here, is this the root folder? Any help would be great...
- thomasmesser
Is possible to support texture sequences or *.avi textures in this script?
Texture sequences can be used if you convert them pr frame. This is done under the OBJ exporter map/texture popup, pick a format and resolution and fly away.
This is not a feature related to the script but a standard feature in the obj exporter.
Note you need to be sure it actually can convert and load the container/codec..
Dont load image sequences like jpg to max standar material, it remaps to an ifl file which octane cant handle, so you need to convert.
Amiga 1000 with 2mb memory card
Is there a way to export the VRay camera path for performing the rendering? I get an error "pos" not defined when I try to do this. Is there a quick way to fix this? Or perhaps can I tie a regular camera to the VRay camera XForm?
Also for some reason, I have to manually execute the script (it does not appear in the customize menu).
Best
8 cores, 12 GB Ram, i7, Win7, 1 Tesla C1060, 1 GTX295
Best
You could constrant the orientation/position from a regular camera to the VRay camera, same with the interestgarmire wrote:Is there a way to export the VRay camera path for performing the rendering? I get an error "pos" not defined when I try to do this. Is there a quick way to fix this? Or perhaps can I tie a regular camera to the VRay camera XForm?
No way yet...garmire wrote:Also, is there a way to render a walkthrough from 3ds without having to reload the OBJ file every time? My OBJ file is very large.
face
http://vimeo.com/user2509578
What do you mean, inside max or octane?
Hello
