OctaneRender for Maya 2020.1.3-17.23 [OBSOLETE]
Moderator: JimStar
Locked
JimStar
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2020.1
Maya® Version Requirements
This release will work with Maya® Versions 2017, 2018, 2019 and 2020 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2020.1
Changes since version 17.22:
  • Implemented the support of vertical fit for camera-mapped images (camera-mapping checkbox in image textures is now a fit-options' selection list).
  • Fixed the upsampling stretching the render result in some un-even-size cases.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
pixerati2
Is the Throw distance control broken for the spotlight? It seems to have little effect except at extremely low values. The same control behaves naturally in the Houdini version. I thought it might be a scale issue, but I've tried all kinds of scene scales with it...?
zurakan
i test Octane Composite Material Node
when create not maya is fatal error
maya 2020.2 and maya 2018.7 same error
Win7 Ultimate x64 xeon Core 40 / maya2Octane 1.20a , maya 2014SP4 & Octane 1.50,
128GB Ram, 4 x GTX Titan 6GB
zurakan
I only have this version on my pc still fatal error
I can use Octane Orbx material >> and use Composite material in side Orbx
JimStar
zurakan
I can't reproduce it, tried different Maya versions - no crashes...
Can you share the Maya dump files (it creates them in the Temp folder after every crash)?
zurakan
AppData\Local\Temp
CrashTemp.rar
CrashTemp.rar
(374.91 KiB) Downloaded 264 times
JimStar
zurakan
Thanks for the dump-files.
This is some Autodesk's fluctuating bug (I can't reproduce it in any Maya versions), happening deeply in Maya's DependEngine.dll library's stacktrace.
Needs to be reported to Autodesk...
Locked
Return to “Releases”
