I talk about this parameter.thanulee wrote:Thanks Ahmet. What is this problem that u describe? When we set texture to "float" for example?aoktar wrote: It's stable enough for me, but only problem with previews when you have texture compressions. Of course, it depends to hardware/driver combinations.
Cheers
Cinema4D version 2020.1.2 (Obsolete)11.06.2020
- eyeonestudio
- Contact:
Just Report : Can not Rendering Volume(VDB), TFD, Fume(VDB) - Win10 / Driver 445.98 / TitanXpaoktar wrote:I talk about this parameter.thanulee wrote:Thanks Ahmet. What is this problem that u describe? When we set texture to "float" for example?aoktar wrote: It's stable enough for me, but only problem with previews when you have texture compressions. Of course, it depends to hardware/driver combinations.
Cheers
C4D R2025 / Win11 / AMD TR WX Series / 256Gb RAM / RTX3090 / 100GbE
I think that the issue is not in High Sierra, but in the old CPU, and AVX instructions.3dworks wrote:same here, macpro mid 2010 with geforce GTX 1080. release 2019 worked like a charm, but this one crashes at startup as a plugin in cinema, but also as slaves and standalone. crash log is this:SRCOBB wrote:Is this latest version no longer going to work on my OSX High Sierra?
My 2010 Mac Pro is stuck at OSX 10.13.6, and the Nvidia driver is 387.10.10.10.40.130. Any system updates make my Nvidia cards unusable.
Octane has worked for me up until now. I can't get the 2020.1.2 standalone to open, and C4D won't open with the plugin installed.
Have I hit the wall?
Process: CINEMA 4D [883] Path: /Production/*/CINEMA 4D.app/Contents/MacOS/CINEMA 4D Identifier: net.maxon.cinema4d Version: 20.1 (0) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: CINEMA 4D [883] User ID: 501 Date/Time: 2020-06-12 20:32:21.345 +0200 OS Version: Mac OS X 10.13.6 (17G13035) Report Version: 12 Anonymous UUID: B841C2F9-C67E-C61A-949C-585831F2E43B Time Awake Since Boot: 200 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_INSTRUCTION (SIGILL) Exception Codes: 0x0000000000000001, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Illegal instruction: 4 Termination Reason: Namespace SIGNAL, Code 0x4 Terminating Process: exc handler [0] Application Specific Information: /Users/3dworks/Library/Preferences/MAXON/C4D20_studio_63FEB824/plugins/c4doctane/liboctane.dylib Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 liboctane.dylib 0x000000011fb41ec2 0x11def6000 + 29671106 1 dyld 0x000000010949aac6 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 420 2 dyld 0x000000010949acf6 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40 3 dyld 0x0000000109496218 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 330 4 dyld 0x00000001094961ab ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 221 5 dyld 0x000000010949534e ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 134 6 dyld 0x00000001094953e2 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 74 7 dyld 0x00000001094893e5 dyld::runInitializers(ImageLoader*) + 82 8 dyld 0x00000001094920a8 dlopen + 527 9 libdyld.dylib 0x00007fff79755d86 dlopen + 86 10 net.maxon.cinema4d 0x00000001079e1f0d 0x107883000 + 1437453 11 net.maxon.cinema4d 0x00000001079e29c4 0x107883000 + 1440196 12 net.maxon.cinema4d 0x0000000107a09035 0x107883000 + 1597493 13 net.maxon.cinema4d 0x0000000107a08e6c 0x107883000 + 1597036 14 net.maxon.cinema4d 0x0000000107a0b115 0x107883000 + 1605909 15 net.maxon.cinema4d 0x00000001078894f3 0x107883000 + 25843 16 net.maxon.cinema4d 0x000000010788947c 0x107883000 + 25724 17 libdyld.dylib 0x00007fff79754015 start + 1
2020.1.x is working correctly here in 2x machines with High Sierra, but the oldest is from 2014.
The core developer team is already investigating the issue.
ciao Beppe
Everything is working as expected here with 2020.1.2 and TFD: Should be something else, please, share more info.eyeonestudio wrote:
ciao Beppe
- eyeonestudio
- Contact:
TFD FFX is Ok. sorry about that.bepeg4d wrote:Everything is working as expected here with 2020.1.2 and TFD: Should be something else, please, share more info.eyeonestudio wrote:
ciao Beppe
But not VDB File. How to render old version VDB files?
I have some vdb assets.
VDB file format compatibility https://groups.google.com/d/msg/openvdb ... vnxNNTCgAJ
222 (OpenVDB 1.0) - First official release of OpenVDB (roughly)
223 (OpenVDB 3.0) - Blosc Compression and Point Index Grids
224 (OpenVDB 3.3/4.0) - Point Data Grids
Weird, but surely an issue with general SDK, not plugin.
Btw, the following vdb file is from 2015, how old is your vdb file? ciao Beppe
- eyeonestudio
- Contact:
TESTED : The files below cannot be rendered.bepeg4d wrote:Weird, but surely an issue with general SDK, not plugin.
PixelLAB Clouds Smoke https://www.thepixellab.net/vdb-smoke-pack-volume-1
EmberGEN Samples https://jangafx.com/software/embergen/d ... nimations/
Bunny is maybe OpenVDB 1.0(very old)
This issue seems to be specific to OpenVDB 3.0 files. Please maintain compatibility.
This is quote from SDK and Standalone topic. Not sure about internal changes and compatibility. This is not about plugin side, asked in to team.eyeonestudio wrote:PixelLAB Clouds Smoke https://www.thepixellab.net/vdb-smoke-pack-volume-1bepeg4d wrote:Weird, but surely an issue with general SDK, not plugin.
Enforce loading VDB files just up to the version currently supported (223).
- fatrobotsneedlove
I cant figure out how to get Cryptomatte working. Currently the Object node puts out an all green pass with outlines and the material node does 2 colors that aren't the same material.
4x 2080ti hybrids, 4x 980ti Hyrbids. C4D, Houdini.
Please, make sure that Live View is in LDR-8bit mode, anyway, the results from Picture Viewer should be correct.fatrobotsneedlove wrote:I cant figure out how to get Cryptomatte working. Currently the Object node puts out an all green pass with outlines and the material node does 2 colors that aren't the same material.
ciao Beppe
