Hi all,
This is the Cinema 4D plugin with latest production ready version 2020.1.2 SDK. Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1.2.
Make sure to use a NVIDIA Studio driver with version at least 435.80 for Windows or 435.12 for Linux to enable support for RTX hardware acceleration. There are no OSX drivers that currently support RTX.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1.2 plugin
- Fix: Compare mode for 8bit-tonemapped buffers
- Fix: missing displacement in composite material from livedb
- Internal changes for universal camera and volume spot light
Note that R21 builds are compatible with S22 and you can use R21 builds in S22
WINDOWS ENTERPRISE BUILD (R15-R21/S22)
https://render.otoy.com/customerdownloa ... .2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21/S22)
OSX ENTERPRISE BUILD (R15-R21/S22)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21/S22)
R15 resources(just for R15 users)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Cinema4D version 2020.1.2 (Obsolete)11.06.2020
Really fast!
Thank you, Aoktar.
Thank you, Aoktar.
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
One question: Has the Film offset inside C4D camera stopped working? I am using "Universal camera type" and I see now the offset no longer responds to the live viewer.
At the first samples, thecamera shift reflects correctly, after a second the camera offset is override to 0 in the live viewer. I wish the "Univeral camera type" had tilt/shift capabilities included.
EDIT: The "Thinlens camera type" responds correctly to C4D Film offset"
Yes correct I missed that because I've refactored the universal camera part.Kalua wrote:One question: Has the Film offset inside C4D camera stopped working? I am using "Universal camera type" and I see now the offset no longer responds to the live viewer.
Is this latest version no longer going to work on my OSX High Sierra?
My 2010 Mac Pro is stuck at OSX 10.13.6, and the Nvidia driver is 387.10.10.10.40.130. Any system updates make my Nvidia cards unusable.
Octane has worked for me up until now. I can't get the 2020.1.2 standalone to open, and C4D won't open with the plugin installed.
Have I hit the wall?
It's stable enough for me, but only problem with previews when you have texture compressions. Of course, it depends to hardware/driver combinations.vesta wrote:thanks a lot Aoktar for your incredible work
Now I'm still on V4, what you say it's time to move on this v2020 ?
Just worried about stability
thanks
Giuseppe
I can use it with High Sierra and the latest available drivers.SRCOBB wrote:Is this latest version no longer going to work on my OSX High Sierra?
Is that on a newer machine? MacBook? Newer Nvidia driver? My hardware (2010 mac pro tower) has me stuck not only on operating system, but on the nvidia drivers, so it's not just High Sierra. If you have it working on similar hardware, then I must have some other issue.aoktar wrote:I can use it with High Sierra and the latest available drivers.
Thanks Ahmet. What is this problem that u describe? When we set texture to "float" for example?aoktar wrote: It's stable enough for me, but only problem with previews when you have texture compressions. Of course, it depends to hardware/driver combinations.
Cheers
same here, macpro mid 2010 with geforce GTX 1080. release 2019 worked like a charm, but this one crashes at startup as a plugin in cinema, but also as slaves and standalone. crash log is this:SRCOBB wrote:Is this latest version no longer going to work on my OSX High Sierra?
Process: CINEMA 4D [883]
Path: /Production/*/CINEMA 4D.app/Contents/MacOS/CINEMA 4D
Identifier: net.maxon.cinema4d
Version: 20.1 (0)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: CINEMA 4D [883]
User ID: 501
Date/Time: 2020-06-12 20:32:21.345 +0200
OS Version: Mac OS X 10.13.6 (17G13035)
Report Version: 12
Anonymous UUID: B841C2F9-C67E-C61A-949C-585831F2E43B
Time Awake Since Boot: 200 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [0]
Application Specific Information:
/Users/3dworks/Library/Preferences/MAXON/C4D20_studio_63FEB824/plugins/c4doctane/liboctane.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 liboctane.dylib 0x000000011fb41ec2 0x11def6000 + 29671106
1 dyld 0x000000010949aac6 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 420
2 dyld 0x000000010949acf6 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
3 dyld 0x0000000109496218 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 330
4 dyld 0x00000001094961ab ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 221
5 dyld 0x000000010949534e ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 134
6 dyld 0x00000001094953e2 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 74
7 dyld 0x00000001094893e5 dyld::runInitializers(ImageLoader*) + 82
8 dyld 0x00000001094920a8 dlopen + 527
9 libdyld.dylib 0x00007fff79755d86 dlopen + 86
10 net.maxon.cinema4d 0x00000001079e1f0d 0x107883000 + 1437453
11 net.maxon.cinema4d 0x00000001079e29c4 0x107883000 + 1440196
12 net.maxon.cinema4d 0x0000000107a09035 0x107883000 + 1597493
13 net.maxon.cinema4d 0x0000000107a08e6c 0x107883000 + 1597036
14 net.maxon.cinema4d 0x0000000107a0b115 0x107883000 + 1605909
15 net.maxon.cinema4d 0x00000001078894f3 0x107883000 + 25843
16 net.maxon.cinema4d 0x000000010788947c 0x107883000 + 25724
17 libdyld.dylib 0x00007fff79754015 start + 1
