How to set gamma/exposure/tone mapping in Blender?
kirk
to get same result in viewport and final render? I am totally lost and always get randomly gamma corrected two times or double linearized something. Then suddenly it's ok.
Is there some rules what should I check in and off?
Q6600, 5GB ram, GF9800gt-1gb, 3dsMax 2008 , Blender , Zbrush, Messiah 3d v5, Terragen 2, Vue 6 Infinity
J.C
1. Go to Render Properties tab in Properties window. Expand Color Management and set:
  • * Display Device to: None
    * View: Default
    * Exposure: 0.0
    * Gamma: 1.0
2. Go to camera tab in Properties window and enable Octane Camera Imager (Render mode)
3. Alternatively go to 3d view Properties panel (N key shortcut), locate Octane Camera Imager (preview Mode) and enable Override. This way all cameras will have the setting from this panel.
System – Windows 11
kirk
Thanks a lot J.C
linograndiotoy
I suggest a slightly different method that can be really useful if you want to work with a color corrected OpenGL but still preserve the fact you can use Octane's color correction tools.
Just leave Display Device to "sRGB" (do not set it to "NONE") and be sure to select "Raw" in View Trasform. That way you'll be able to work with an sRGB OpenGL view and also correct colors in the Shader Editor.
kirk
Thanks linograndiotoy, it does work
protovu
I like it. Thank you, Lino.
linograndiotoy
You're welcome!
Return to “Blender”
