OctaneRender 2020.1 LightWave Beta build 2020.1.0.6
marchermitte
Well, as you can see with the SC, even though I can access and edit the kernel properties, instances are still nor rendred. The only geometries that get rendered are the complementary objects I added to my scene (corridor floor, corners, etc
The instances you can see in the wireframe view are not rendered at all. Now I didn't use Octane for a long time (I know, why?) and I might have forgotten something very basic.
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
juanjgon
marchermitte wrote:Yeap, I just installed LW 2019 and Octane plugin works perfectly, I can access the kernel node properties without any trouble. So I think that the lw 2019 version of the plugin doesn't work completely with LW 2020.01.
But there is a proper plugin build for LightWave 2020.0! Why are you using the Octane plugin for LW2019 in LW2020?
juanjgon
marchermitte wrote:Well, as you can see with the SC, even though I can access and edit the kernel properties, instances are still nor rendred. The only geometries that get rendered are the complementary objects I added to my scene (corridor floor, corners, etc
I'm not sure what could be the problem. Can you send me this scene to take a look at it here?
marchermitte
Oh there is a plugin for LW 2020? Ok, I didin't see It.
Ok, that fixed the kernel nod not opening It's properties problem.
I sent you the link to the scene via pm
Thank you
Marc Hermitte
wavesoflight
I am trying to use Spectron Lights with Octane 2020.1.0.6 (and the same with Octane 2020.1.0.7) with LW2015.3
It doesn't matter what I do, even with a simple scene (one Octane light, ground plane and cube) the following errors can occur:
The minute I try to change the parameters of any node inside of the Spectron node Editor, whilst IPR is open, LW crashes.
Sometimes, if I have the node editor open and try and close IPR, LW crashes.
With the Spectron node editor open and nothing connected to the main node - launching IPR crashes LW.
I'm using NVidia drivers 441.41 Standard.
Hope this helps.
juanjgon
Hmm, are you sure that you are working with the LW2015 plugin? I was not aware of a problem like that. You can check the installed Octane for LW plugin version in the "About" window.
Attached you have a demo scene including spectron spotlights. Does it work in your system?
spectron.zip
(504.82 KiB) Downloaded 215 times
Return to “Lightwave 3D”
