Beware of "3ds Max gamma hack"! :(
javierluisbravo
maybe when saving the jpg you have activaded in the save panel the overide of the gamma in 1.0 and that should be in 2,2 or in automatic for jpg which are to be seen in srgb monitors :)
tcheng00
I can confirm that using Max gamma hack and non linear tone mapping clamps the dynamic range from 0 to something slightly above 1. I'm assuming the slightly above 1 value helps the post effect, but ideally, we should have full range with the Max Gamma Hack and non linear tone mapping. It only makes sense that I can still use the color management of Octane and still take advantage of the 32-bit float EXR range.
paride4331
samsue wrote:
paride4331 wrote:Hi javierluisbravo,
Gamma/LUT setup:
Enable Gamma/LUT correction
Gamma 2,2
Affect Color selectors on
Affect Material Editor on
Kernel panel setup:
3ds Max gamma hack on
imager panel Render Setup:
non linear tone mapping on
Gamma 2,2
Response Linear/off
Octanecamera imager panel:
Gamma 2,2
Response Linear
paride4331, my life got more complicated again.
Gamma/LUT setup:
Gamma 2,2
Kernel panel setup:
3ds Max gamma hack on /off
Gamma 2,2 / 1.,0
Response Linear/off - sRGB
Gamma 2,2 / 1,0
Response Linear / sRGB
I've tried several combinations, my rendering always comes out with dark gamma.
Hi samsue,
samsue
paride4331 wrote:
Gamma/LUT setup:
Gamma 2,2
Kernel panel setup:
Gamma 2,2
Response Linear/off
Gamma 2,2
Response Linear
Gamma/LUT setup:
Gamma 2,2
Kernel panel setup:
Gamma 2,2 / 1.,0
Gamma 2,2 / 1,0
Hi samsue,
now you've offended me. :o
samsue
how can that be! Even to save an image turns into a nightmare
Someone can give me a setup that saves a simple 2.2 gamma image like I see on viewport? because I don't know what else to do.
I don't know anymore if what's on the prinscreen is right... I tried everything
paride4331
Hi samsue,
Gamma/LUT setup:
Gamma 2,2
Kernel panel setup:
3ds Max gamma hack > off
non linear tone mapping > on
Gamma > depends on response
samsue
still save darker...
HHbomb
I do save images in gamma 2.2 ( each time ) and almost the same settings as Paride : linear, maxhack off.
samsue
usually, too, I don't know what's going on here.
remKa
Hello Paride,
using your settings (with gamma hack ON), I have this issue :
- Images on top are from the Octane Viewport, Beauty and denoised Beauty are fine
- Images on bottom are from the 3ds Max Frame Buffer, denoised beauty pass has a wrong gamma
What should I do ?
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
Return to “Autodesk 3Ds Max”
