Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
Kalua
aoktar wrote:Some little improvements on Nodes
Thanks for highlighting this feature, Aoktar!!
I was wishing for this beahavior in node editor for some time now.
Is this already implemented or is for the next build?
Cheers,
C4D 2025.3.3 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
blackcat321
When I render the image to PV and switch the LV preview, octane often crashes. I've crashed several times in an hour, and I've uploaded multiple crash logs. I use 980ti * 2 and drive 445.87 win10 1909
bugreport_20200516_104930.zip
(1.74 KiB) Downloaded 204 times
bugreport_20200516_103932.zip
(1.65 KiB) Downloaded 183 times
bugreport_20200516_102940.zip
(2.08 KiB) Downloaded 179 times
eyeonestudio
Adjusting the parameters(Exposure, Gamma, Custom Lut....) in the "camera imager" will recalculate samples.
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
eyeonestudio wrote:Adjusting the parameters(Exposure, Gamma, Custom Lut....) in the "camera imager" will recalculate samples.
Have you tried on different conditions and scenes? Probably there is some objects that trigger updatr
blackcat321 wrote:When I render the image to PV and switch the LV preview, octane often crashes. I've crashed several times in an hour, and I've uploaded multiple crash logs. I use 980ti * 2 and drive 445.87 win10 1909
to give more info,
-on a specific scene?
-using RTX?
-tried to clear texCache?
-Using studio version of driver?
eyeonestudio
I use very simple scene
https://ibb.co/VHDY8B4
please send this scene
eyeonestudio
https://ibb.co/VHDY8B4[/quote]
please send this scene[/quote]
R19 + 2020.1.RC3 - Ok
S22 + 2020.1.RC3 - Recalculate (maybe C4D Problem)
test.zip
test scene
(60.59 KiB) Downloaded 186 times
eyeonestudio wrote:I use very simple scene
test.zip
[/quote]
ok It's happening in S22, but not in other builds
nscr
How can I just solo the map I'm making in the Bump channel? When I try to solo a texture node connected to Bump (or any node connected to Bump) the Live Viewer just goes black. There are a few other channels that give this same result.
Return to “Releases”
