Shadow catcher not dark enough
javierluisbravo
My friends,
why shadow catcher is not so dark?
is there a way to make it darker?
Here attached example comparison between vray, octane and clarisse.
paride4331
Hi javierluisbravo,
are you sure your linear workflow is set correctly?
javierluisbravo
yes my friend...
i worked in LWF since ages with vray... For sure i am kind of new to octane.. as i started to use it i think 2 years ago..
i had no trouble with my LWF in octane since this 2020.1 version that the defaults changed and i want to start moving from linear srgb to linear ACEScg.
javierluisbravo
take a look to this...
for me is a clear issue in the contribution of the alpha channel of the shadow catcher...
javierluisbravo
i solved this one!
frankmci
javierluisbravo wrote:i solved this one!
Please share how you solved it, in case others run into the same issue.
javierluisbravo
Totally!
I used a Octane sun below the horizon to kill the shadows and i mapped it with and HDRI (gamma 1 for sure) in the texture... and i changed the dropdown from daylight to texture...
and the SIBL is working perfect now :) compared with Redshift and Vray.
Anyway there are gamma issues in the octane 2020.1 regarding the defaults... so i used gamma hack off and nonlinear off too.
javierluisbravo
Here comparison...
vray and octane working very close now :)
The best version is the AcesCG from clarisse .
it feels more natural and more real because all is AcesCG color managed...
Return to “Autodesk 3Ds Max”
