Can Octane Lights update in real-time in Viewport?
reidstudio
Is there a way to get real-time updates with an OctaneLight in the Octane viewport?
It seems like other lights have more immediate feedback, but the only way to see any change with these lights it to rebuilt the entire scene every single time. Is there a configuration or something I'm missing to get lights to provide some responsiveness in the real-time workflow?
EDIT: So it looks like disabling Quick Mode can help with making some changes - like intensity. But it still requires Updating Scene Geometry if I add or move lights/geo (which seems odd).
paride4331
Hi reidstudio,
select all objects (ctrl+a)
mouse righclick > Octane properties
set "all movable"
restart the scene
HHbomb
Personnally I use this script for years....
Place it in script/startup/ of your max version and all new object is a Movable Proxy. I never worry about.
OCT_MPAUTO2new.zip
(479 Bytes) Downloaded 216 times
paride4331
Hi HHbomb,
you can also set all movable poxy as default in Octane global preferences > Main settings
reidstudio
Thank you! That setting is exactly what I was looking for.
Return to “Autodesk 3Ds Max”
