Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
HTK421 wrote:Node connector lines appear in front of some nodes.
In this example I moved the Material Layer 2 node, but the other connectors remained in front.
Screen shot and scene file attached
It's same since many versions, not avoidable
shine71 wrote:Hi Ahmet!
Could you tell me where I could find previous reease? (2020.1-R1)
I tested it and it worked fine, this one is crashing once I open same files that yesterday worked like a charm....
Cheers
Check other posts in this forum pls
shine71
Cheers
Hi Ahmet!
I did before writing, but there are experimental and RC versions, not the stable R1....
I7 5930k - 32 Gb ram - 2 x RTX 2080ti
http://www.marcodattilo.com
divasoft
divasoft wrote:Another bug. Picture viewer not render xParticles Generator meshes, but they are in Live viewer.
particles are cached.
Scene https://yadi.sk/d/8Yk9zVApWoJ3IA
Previous bug with incorrect denoiser result, please see my post in this thread.
And AaronWestwood confirmed the same problem
viewtopic.php?f=85&t=74603&start=70#p382046
About the particles. What else could it be if it is not a bug? I rolled back to version 2019 and it works well. Particle meshes are rendered there. In 2020.1 no. I attached the scene to the post, look carefully.
Cheers
Hi Ahmet!
Ah ok! Btw there's not a change can cause crashes on this build over previous.
https://render.otoy.com/customerdownloa ... .1_win.rar
https://render.otoy.com/customerdownloa ... Macosx.zip
divasoft wrote:Ahmet, In this release denoiser produce incorrect result (right).
i sent this scene to your
Hi divasoft, the issue is related to the general SDK, I have already forwarded your report to the core devs, I’ll keep you posted on this.
ciao Beppe
shine71
Thanks Ahmet!
I will try, I saw a different behavior, don't know why...
Sincerely I'm fighting for days with these new releases, both 2019 than 2020.
And when I start to meet too many crashes I install 4.05 R7 that works always like a charm..
Thanks again for your work and support!
Cheers!
divasoft
ciao Beppe
It's great, thanks)
shine71 wrote:Thanks Ahmet!
Cheers!
Try to delete texture cache, with "Empty texCache" command
wrapthereal66
hey ! thanks you very much for the update ! the performance improvement is huge !!
i find a bug really important : the solod node feature on the material node editor don't work ! :/
Return to “Releases”
