Crash on rendering material
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Frez121212
A. Windows 10 Version 1909
B. 2X 2080 Ti + 1X 1080 Ti
C. 32 GB RAM
D. Nvidia driver version 442.92
E. OctaneRender Standalone version, OctaneRender Enterprise 2019.1.5
F. OctaneRender plugin version 2019.1.5-R3
G. Cinema 4D R21.27 (RC)
H. These materials along with several others in my library crash my cinema 4d immediately upon rendering. They also crash when trying to edit material from these scenes.
Several of my library objects are un-usable as a result.. my entire library has turned into a minesweeper game of which is going to destroy my scene.
I. Copies of the Log attached
Ficus Elastica (Rubber Plant).zip
The scene that crashes .. along with textures.. preview was made when there were no issues with the scene.
(53.01 MiB) Downloaded 298 times
_BugReport.txt
(614.57 KiB) Downloaded 281 times
Started after a change on your PC?
Frez121212
Hi. Not sure when it started. But maybe! I brought some of my video cards home from work when my company started working from home. I always used two PC though, one from home and one from work, and I sync all my files and use both to develop projects and assets... but yes I did modify the home 6-7 weeks ago.
Frez121212
Actually the scene that made me realize something is wrong, I made it last week.. I imported that plant and several other assets to a scene and it rendered fine.. then on Saturday when I rendered it, it would crash.. I didn't make any hardware changes since when it WAS working for that particular scene.
Frez121212
Hi, any ideas? Its still happening in octane 2020.1
OK send me a Pm for private connection to your pc if you wish me check it
DARIOALVA
The same is happening to me. Some materials that worked on V4 are crashing on Octane 2020.1. I'll try to provide bug report soon.
Please try to delete texCache with "Empty texCache" command. This solved the problem of Frez121212.
DylanWrankmore
That did actually work! Thanks so much!!
Windows 10 / Asus X9-E WS / i7-6850K / 64GB RAM / GTX 970
Octane Standalone v3.01.1 / OctaneRender for C4D 3.02-R2 / Nvidia driver 368.39
kasradesign
Getting lots of crashes lately. For example, when the live viewer is rendering, if I switch off and on octane lights (green tick), it simply crashes and I get the pop up saying this plugin is crashed, find the report here etc. And my machine is no ordinary. It is quite high-end.
System Info:
RTX 3090
i7 10700
32 GB Ram
Windows 10
Octane version: 2020.2.3-R3
Cinema 4D R21
I tried emptying the texture cache but no avail. Generally since I started my subscription with this 2020 version, many actions can cause crash making me feel like this version is quite unstable.
Please advise.
Return to “Bug Reports”
