Sample scene required, I cannot repro itAleksei wrote:If in Octane camera tag I turn on sampling mode the image in the viewport gets distorted.
Cinema 4D R19.068 on Windows 10.
Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
OSX R20 was wrong. Fixed now with newer builds.iamcyclo wrote:Hello,
I have been having an issue with launching Octane I am currently running the latest version of Cinema 4D R20 and the latest studio drivers.
I can get cinema to open OctaneStudio-for-C4D-2019_1_5-R3-win
but if I try to go any version that is newer of 2019 or 2020 my cinema 4d gets stuck on launch at initializing plugins. If I downgrade versions of octane it works fine.
not sure how to get this to work.
Thank You
Thomas
Try with 2020.1-R2 build, should be fixed!bloomis2 wrote:Hi, thanks for the great release!
Just a thing: when I click on Compare > Store render buffer, the image stored is out of proportions and I can't move the line bewteen A and B anymore.
I had no issues with the RC3 regarding this.
ACES in LV is same thing in Linear ACES in render settings.paypal-ict wrote:Anyone found a proper way to work with ACES / OCIO? I found this new icon in the live viewer, which you can toggle:
LDR 8-bit
HDR
HDR Linear
ACES
And in the rendersettings in Cinema4D there's a new option under Render buffertype: Linear ACES 2065-1
And in multipass options you can also set the Tonemap type to: Linear ACES 2065-1
But how can I show the Live Viewer as usual but use the ACEScg workflow? I tried applying a LUT in the camera imager wile LiveViewer is set to ACES-mode, but nothing happens.
ACES + HDR linear, both are linear. So tone mapping effects are not applied to keep them not distorted.
I don't have any habits, just trying to make this s*** best. Of course, I see every report and trying to fix. For major releases, we have incredible many messages/things to be care of. I cannot give feedback to everyone to have more time to work on.VVG wrote:aoktar wrote:I know it, do you think I sleep without working. I can't work if I answer every messages. Be patient please.VVG wrote:Ahmet,
how many times do I still need to show you this problem?
viewtopic.php?p=381224#p381224
viewtopic.php?p=380949#p380949
Thanks for the release
Do many people send bugs to you on the forum?
10/100/1000 people?
You have a habit of not responding to problems.
I have repeatedly said that no one asks to quickly fix the problem, especially since it is not critical.
You just need to answer that you are busy solving this problem. That's all I'm waiting for.
Sorry for the concern, Ahmet, but could you say something about the inconsistency between the version of c4d octane and the slave node? My work is idle.
UPD: I am a little confused in the versions, now everything is fine. Thanks, help is no longer required.
- AaronWestwood
I havn't been able to replicate this, it's always black for me when Visible Environment is selected. Even on final render to picture viewer it stays black which is a HUGE deal breaker. Hopefully we see a fix for this ASAP.frankmci wrote: I'm seeing this only when switching back and forth between Primary Environment and Visible Environment. Re-sending the scene seems to fix it.
The 2020 features are too good to roll back, but i'm held up with rendering projects until we get this sorted
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
- paypal-ict
But where can I find the OCIO support mentioned in the release notes? "Advanced Display Color Management System | OCIO"aoktar wrote:ACES in LV is same thing in Linear ACES in render settings.paypal-ict wrote:Anyone found a proper way to work with ACES / OCIO? I found this new icon in the live viewer, which you can toggle:
LDR 8-bit
HDR
HDR Linear
ACES
I should be able to apply OCIO in the Live Viewer somehow, right?
aces is just supported in export - we were going to have ocio in C4D itself, but will be instead be working on our our display system. Because octane is spectral in core, sky, blackbody, etc just work without OCIO. In 2020.1 we have tested OSL nodes for RGB image to ACES, but we are working on a. fully built in color space node to solve this definitively along with the display work. Octane X on Metal does have the new display (in standalone) but it is a version or two ahead of 2020.1 right now.paypal-ict wrote:But where can I find the OCIO support mentioned in the release notes? "Advanced Display Color Management System | OCIO"aoktar wrote:ACES in LV is same thing in Linear ACES in render settings.paypal-ict wrote:Anyone found a proper way to work with ACES / OCIO? I found this new icon in the live viewer, which you can toggle:
LDR 8-bit
HDR
HDR Linear
ACES
Awesome, it works! Thank you, you're fastaoktar wrote:OSX R20 was wrong. Fixed now with newer builds.iamcyclo wrote:Hello,
Thank You
Thomas
Not a major issue but I'm just letting you know: the image jiggles a little when you slide the cursor between A and B images.
Thanks for your hard work!
