Which drivers are you using?Clarawhite wrote:Hi, I can't seem to turn on the RTX acceleration. I have 3x RTX 2080 and updated to the latest studio drivers, but it's just grayed out every time I try to use it.
Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
Hi, Yes I'm using 150% scaling, but it was never an issue with Octane.aoktar wrote:Are you using desktop scaling?bloomis2 wrote:Hi, thanks for the great release!
Just a thing: when I click on Compare > Store render buffer, the image stored is out of proportions and I can't move the line bewteen A and B anymore.
I had no issues with the RC3 regarding this.
Turning it off fixed it, but it's a pain to work on a 4K monitor without scaling...
- Clarawhite
Hi, I just downloaded the latest nvidia studio drivers from their site 430.86. Everything else in the plug in is working. C4d is updated fully as well. I seem to remember it working fine in a test version i tried a few months ago, but now the box is untickable. Very strangenejck wrote:Which drivers are you using?Clarawhite wrote:Hi, I can't seem to turn on the RTX acceleration. I have 3x RTX 2080 and updated to the latest studio drivers, but it's just grayed out every time I try to use it.
- AaronWestwood
Sorry to double up on this. Just wondered if anyone else is getting this issue? Hoping for a workaround otherwise ill roll back to 2019 in the meantime...AaronWestwood wrote:A small thing, denoiser isnt rendering Visible Environments as per attachment(just renders as black)
Am I missing something that's changed since 2019?
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
VVG wrote:tonemap color icon It doesn’t look very good.
Must be done in gray colors
I disagree. It's not about looking good, it's about functionality. The tonemap button shows you a reasonable approximation of what you can expect from each option. That's far more intuitive than another gray button. I quite like it.aoktar wrote: I know it, do you think I sleep without working. I can't work if I answer every messages. Be patient please. Do you have a better advise for button?
Yes because displaying render buffer system changed to support desktop scaling. Appearently I forgot to adopt this part. I'll take a lookbloomis2 wrote:Hi, Yes I'm using 150% scaling, but it was never an issue with Octane.aoktar wrote:Are you using desktop scaling?bloomis2 wrote:Hi, thanks for the great release!
I'll test it, it's not a plugin related issue BTW. Propably a core problem or something elseAaronWestwood wrote:Sorry to double up on this. Just wondered if anyone else is getting this issue? Hoping for a workaround otherwise ill roll back to 2019 in the meantime...AaronWestwood wrote:A small thing, denoiser isnt rendering Visible Environments as per attachment(just renders as black)
Your perpetual license will come with the final 2020 release - this is the first.zoppo wrote:.
I have bought a perpetual 2020 and up until now Live Viewer showed "0 days left"
But with this release it started counting down:
I'm seeing this only when switching back and forth between Primary Environment and Visible Environment. Re-sending the scene seems to fix it.aoktar wrote:I'll test it, it's not a plugin related issue BTW. Propably a core problem or something elseAaronWestwood wrote:Sorry to double up on this. Just wondered if anyone else is getting this issue? Hoping for a workaround otherwise ill roll back to 2019 in the meantime...AaronWestwood wrote:A small thing, denoiser isnt rendering Visible Environments as per attachment(just renders as black)
- AaronWestwood
Thanks Aoktar. 2019 has this working, if that helps at all.aoktar wrote:I'll test it, it's not a plugin related issue BTW. Propably a core problem or something elseAaronWestwood wrote:Sorry to double up on this. Just wondered if anyone else is getting this issue? Hoping for a workaround otherwise ill roll back to 2019 in the meantime...AaronWestwood wrote:A small thing, denoiser isnt rendering Visible Environments as per attachment(just renders as black)
