Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
VVG
Ahmet,
how many times do I still need to show you this problem?
viewtopic.php?p=381224#p381224
viewtopic.php?p=380949#p380949
ps
tonemap color icon It doesn’t look very good.
Must be done in gray colors
Thanks for the release
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
AaronWestwood
A small thing, denoiser isnt rendering Visible Environments as per attachment :) (just renders as black)
Am I missing something that's changed since 2019?
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
wayart wrote:How to use Spectron Area/Sphere Primitives?
use an Octane Area Light, choose in the Details the Area Shape (Rectangle or Sphere only for now), then enable the Use Primitives option in the Octane Light tag:
ciao Beppe
In Light Tag, activate "use primitives" parameter and use AI lights in kernel
VVG wrote:Ahmet,
ps
I know it, do you think I sleep without working. I can't work if I answer every messages. Be patient please. Do you have a better advise for button?
zoppo
I have bought a perpetual 2020 and up until now Live Viewer showed "0 days left"
But with this release it started counting down:
C4D 2025 | Win10
VVG
aoktar wrote:
VVG wrote: ps
The previous version was better.
The button is not intended to select multiple options and its design is not very good
VVG
aoktar wrote:
VVG wrote:Ahmet,
Do many people send bugs to you on the forum?
10/100/1000 people?
You have a habit of not responding to problems.
I have repeatedly said that no one asks to quickly fix the problem, especially since it is not critical.
You just need to answer that you are busy solving this problem. That's all I'm waiting for.
mitchino
Do c4d noises work with displacement? I can't seem to get that to work, tried plugging a c4d noise into displacement, no result, tried plugging c4d noise into bake texture then displacement, Octane froze.
helloarty
Hello and thanks for release! Which things I found for now:
1. Bounds doesn't work for Vectron fractals anymore. It was all good in previous version except stability and speed :(
2. Still didn't figure out how to use displacements for VDB clouds. OSL can't compile there for some reason, noise and imagetexture doesn't work too.
3. ACES doesn't respond to gamma changes anywhere
Anyway, it's a great step for Octane! Proud to be it's user :)
Return to “Releases”
