Productivity Features
spartan00j
Hey Paul,
I just recently started using octane again after taking a break from animating for about a year-and-a-half. I wanted to request small adjustments for productivity's sake.
1. I know I asked for an undo feature when changing settings around two years ago. is that still not possible?
2. Also, I know you can right-click a texture (Or multiple) and converted to diffuse but can there be added a feature where you can convert it to any other types of materials with one click? Like if I want it to select 10 textures at the same time and convert all of them to toon materials.
3. And lastly is there a way to change one setting with all selected material nodes. For example, if I right-click on the roughness node setting value in one material node and click copy. And then I will select five other material nodes and right quick and click paste. To change all the roughness node settings of those material knows node that I selected to the value that I copied in step one. Instead of going into each material node one-by-one and changing the roughness node value.
P.S Good to be back and see all the great changes to the plug-in and Octane.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Hi
1) still not possible sorry
2) I don't think this would be viable - sorry
3) You can partially do this currently with dial linking
spartan00j
face_off wrote:Hi
Hey, Paul
I understand your answer for 1 and 3. But I don't understand 2. How is it not viable. Or how is it viable to only convert multiple materials to diffuse materials and not glossy, metallic, mix, specular, etc.
Win 11
128GB RAM
RTX 3060 TI
Can you be more specific in how you are currently converting multiple materials to Diffuse please?
spartan00j
When I hold down the shift or control button to select multiple material nodes and right-click. I only can change them all to diffuse and not any other material node, like Toon, Glossy, etc.
Win 11
128GB RAM
RTX 3060 TI
spartan00j
Also about the mouse wheel move slider feature. It feels kind of weird that I have to move the mouse wheel down to move the slider up and move the mouse wheel up to move the slider down. Can you add an invert option to that feature? So when I moved up the mouse wheel the slider will go up and if I move the mouse wheel down the slider will go down.
Thanks paul
Win 11
128GB RAM
RTX 3060 TI
Unfortunately opening this function up to convert the material to any material type is not as simple as it sounds. You can control the material type that a Poser material is converted to in OctaneDefaults.py (the GLOSSY_DIFFUSE_RATIO parameter). In addition to this, Poser materials with a "Physical Material" will be converted to Universal materials. I would have thought the Toon material would not be usable, as it really needs the Toon Lights, which the Poser plugin does not support.
The hovering of the mouse on the slider and spinning the mouse wheel behavior appears to be controlled by wx.python (the built-in python GUI), and not able to be changed, sorry.
Return to “Poser”
