add key chromakey deletion
- Elvissuperstar007
- Contact:
We could build an OSL script for this, and maybe later bake it into the core if enough want this built in.
Done - will ship as a built in node.Elvissuperstar007 wrote:add key chromakey deletion
- colorkey.orbx
- (5.03 KiB) Downloaded 228 times
- Elvissuperstar007
- Contact:
thanks, it is necessary to integrate into the octane
- Elvissuperstar007
- Contact:
How to make opacity with this OSL?Goldorak wrote:Done - will ship as a built in node.Elvissuperstar007 wrote:add key chromakey deletion
I had a quick look at this. The original script was for 3ds max and has 2 outputs (1 color and the other float)
https://github.com/ADN-DevTech/3dsMax-O ... lorKey.osl
In Octane, we can only have 1 output per OSL node, and it only supports a "color" output.
You would need to use 2 OSL nodes. eg make 2 copies of the script and modify 1 to use the "Col" color output, and the other to use the "Key" float (converted to color).
EDIT: Here is a sample orbx with 2 OSL scripts. I don't know how this is meant to work, but here is a screenshot of 2 planes. You can see through the top one which uses the key as opacity
- colorkey_002.orbx
- (298.58 KiB) Downloaded 229 times
It would be nice if Octane OSL could be updated in the future to allow multiple outputs (as well as different output types like float/int etc)
It would make nodes like this much easier to create (no need for multiple edited copies)
