Hi Simon,
At least for me, when updating a texture map for material, the Render Preview pretends to update, but does not. Refreshing the viewport separately is required.
Rick
octane_carrara_2019.1.05.05_ENTERPRISE
win 64
amd ryzen
64 ram
2x RTX 2080Super
view port refresh required with texture update
I need more details. What kind of changes are you making. I can change bitmaps and I see the change right away. What shader properties are you changing? Can you post an example?
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Hi Simon,
Please see attached pdf.
It shows the steps to generate what I am referring to.
- shader update issue.pdf
- (217.42 KiB) Downloaded 803 times
