Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
jeremyshin
Hello,
I have repetitive and random crash with octane.dll when I just turn on the Octane live viewer.
I am on latest version of c4d plugin and Nvidia Driver on 441.66.
I attached the octanelog and the bug report.
[EDIT] It seems that a wrong texture path caused the crash. I was using several Kitbash3d elements and when I wanted to relink textures, c4d picked up the texture path from the wrong pack (yes... some texture file name are similar from a pack to another). I still don't know why it would crash but I relinked everything with the right pack and everything ran smooth.
_BugReport.txt
Bug Report
(477.41 KiB) Downloaded 357 times
c4doctanelog.txt
C4D Octane log
(11.32 KiB) Downloaded 294 times
jeremyshin wrote:Hello,
It's a crash on the renderer. Does it help if you turn off the "multi-threading for materials"?
rclassenphoto
After the new Windows Update the plugin dont work correct. if i fire up octane c4d crashes or it dont render in the live viewer, please help! I can not work with this.
rclassenphoto wrote:After the new Windows Update the plugin dont work correct. if i fire up octane c4d crashes or it dont render in the live viewer, please help! I can not work with this.
More info would be great! What do you see in console/c4doctanelog.txt and also in bugreport.zip?
rclassenphoto
There is no bug report. Cinema 4d stops responding and I have to end it via the task manager. Its windows 10 with two Titan RTX 24GB and the newest C4D version of R21 with Nvidia Studio Driver 442.19 . After the new windows update i dont can fire up octane.
rclassenphoto wrote:There is no bug report. Cinema 4d stops responding and I have to end it via the task manager. Its windows 10 with two Titan RTX 24GB and the newest C4D version of R21 with Nvidia Studio Driver 442.19 . After the new windows update i dont can fire up octane.
c4doctanelog.txt is always available. Btw you can downgrade to old driver for a solution.
rclassenphoto
Sorry but it is not a available. I use the setup with the Nvidia Studio Driver 442.19 since weeks no Problem now windows installed the new update KB4535996 it dont works.
rclassenphoto
Here is the latest octane log:
[2020-03-04 01:42:15][1] Register OctaneLive
[2020-03-04 01:42:15][0] Loaded Octane DLL:OctaneRender Enterprise 2019.1.5 version:6000500 SDK:2019.1.5
[2020-03-04 01:42:15][0] Octane Render for Cinema 4D 2019.1.5-R3 built for:210 C4D vers:21207
[2020-03-04 01:42:15][0] C4D:21207 comp:[Workstation] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 18363) opengl:460 versType:10
[2020-03-04 01:42:15][0] CPU:[AuthenticAMD, stepping 1, model 1, instruction family 15] speed:4 GHz numOfCpu:32Ht
[2020-03-04 01:42:15][0] Plugins:[houdiniconfig 3dquakersR21 addons advanced render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4dOctane-R21 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deployment dwg dwgobjects dynamics exchanges expressiontag fbx ForesterR21 gpurenderer hair HDRI Browser R21 HDRI Link R21 hot4dr21 i_skp io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor_material objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking particles tpoperators TurbulenceFD_R21_1452 uvviewport volumes walkthrough X-Particles_21 xpressocore xtensions ]
[2020-03-04 01:42:15][0] NVAPI initializing...
[2020-03-04 01:42:15][0] NVAPI Version: NVidia Complete Version 1.10
[2020-03-04 01:42:15][0] Nvidia driver version:441.66 [r441_58]
[2020-03-04 01:42:15][1] LoadOslScripts()
[2020-03-04 01:42:15][0] Loaded 173 osl scripts from dir:C:\Program Files\Maxon Cinema 4D R21\plugins\c4doctane\res\osl_scripts
[2020-03-04 01:42:15][1] LoadCustomLuts()
[2020-03-04 01:42:23][1] <markMaterials>
[2020-03-04 01:42:23][1] RestoreLayout(secret=69bec690)
[2020-03-04 01:42:23][1] InitFromRestoreLayout
[2020-03-04 01:42:23][1] setResFromRndSettings 0x00000284719BFD80 [OK]
[2020-03-04 01:42:23][1] initOctaneLive()
[2020-03-04 01:42:23][1] Init OctaneLive...[2020-03-04 01:42:23][1] Plugin initialized.[2020-03-04 01:42:23][1] Plugin activation...[2020-03-04 01:42:28][1] Plugin activation OK.[2020-03-04 01:42:28][1] Activation time=4.635 sec.
[2020-03-04 01:42:28][0] readDeviceSettings E:01 P:01 T:01 D:01
[2020-03-04 01:42:28][1] Daemon listener -> slave0: RENDERSLAVE state:4 IP:192.168.178.43
[2020-03-04 01:42:28][0] VRAM used/free/max:0Kb/24Gb/24Gb Out-of-core used:0Kb RAM used:12.456Gb total:127.871Gb OpenGL free/total:0/0
[2020-03-04 01:42:28][1] Device:0 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:38
[2020-03-04 01:42:28][1] Device:1 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:44
[2020-03-04 01:42:28][1] setInteractive(1)[OK] [2020-03-04 01:42:28][1] readPrmsFrScn(1)
[2020-03-04 01:42:28][1] processRegions()
[2020-03-04 01:42:28][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:0.548ms. [OK]
[2020-03-04 01:42:28][1] setExportStatus(st=9, flg=0, thr=0)
[2020-03-04 01:42:28][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:0.403ms. [OK]
[2020-03-04 01:42:29][1] Daemon listener -> slave0: RENDERSLAVE state:5 IP:192.168.178.43
[2020-03-04 01:43:23][1] checkNewVersions()
[2020-03-04 01:43:25][1] resetOrbxRootGraphs()
[2020-03-04 01:43:25][1] readPrmsFrScn(0)
[2020-03-04 01:43:25][1] readPrmsFrScn(1)
[2020-03-04 01:43:25][1] readPrmsBC 11111[2020-03-04 01:43:25][0] restoreDeviceStates status:2
[2020-03-04 01:43:25][0] setDevicesActivity rDevices:01 nDevices:01
[2020-03-04 01:43:25][0] save
rclassenphoto
i install the old 441.66 driver now octane crashes directly with a error. And i get this:
[2020-03-04 01:50:10][1] Register OctaneLive
[2020-03-04 01:50:10][0] Loaded Octane DLL:OctaneRender Enterprise 2019.1.5 version:6000500 SDK:2019.1.5
[2020-03-04 01:50:10][0] Octane Render for Cinema 4D 2019.1.5-R3 built for:210 C4D vers:21207
[2020-03-04 01:50:10][0] C4D:21207 comp:[Workstation] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 18363) opengl:460 versType:10
[2020-03-04 01:50:10][0] CPU:[AuthenticAMD, stepping 1, model 1, instruction family 15] speed:4 GHz numOfCpu:32Ht
[2020-03-04 01:50:10][0] Plugins:[houdiniconfig 3dquakersR21 addons advanced render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4dOctane-R21 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deployment dwg dwgobjects dynamics exchanges expressiontag fbx ForesterR21 gpurenderer hair HDRI Browser R21 HDRI Link R21 hot4dr21 i_skp io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor_material objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking particles tpoperators TurbulenceFD_R21_1452 uvviewport volumes walkthrough X-Particles_21 xpressocore xtensions ]
[2020-03-04 01:50:10][0] NVAPI initializing...
[2020-03-04 01:50:10][0] NVAPI Version: NVidia Complete Version 1.10
[2020-03-04 01:50:10][0] Nvidia driver version:441.66 [r441_58]
[2020-03-04 01:50:10][1] LoadOslScripts()
[2020-03-04 01:50:10][0] Loaded 173 osl scripts from dir:C:\Program Files\Maxon Cinema 4D R21\plugins\c4doctane\res\osl_scripts
[2020-03-04 01:50:10][1] LoadCustomLuts()
[2020-03-04 01:50:18][1] <markMaterials>
[2020-03-04 01:50:19][1] RestoreLayout(secret=6298c870)
[2020-03-04 01:50:19][1] InitFromRestoreLayout
[2020-03-04 01:50:19][1] setResFromRndSettings 0x0000023CA2CDF400 [OK]
[2020-03-04 01:50:19][1] initOctaneLive()
[2020-03-04 01:50:19][1] Init OctaneLive...[2020-03-04 01:50:19][1] Plugin initialized.[2020-03-04 01:50:19][1] Plugin activation...[2020-03-04 01:50:23][1] Plugin activation OK.[2020-03-04 01:50:23][1] Activation time=4.635 sec.
[2020-03-04 01:50:23][0] readDeviceSettings E:01 P:01 T:01 D:01
[2020-03-04 01:50:23][1] Daemon listener -> slave0: RENDERSLAVE state:4 IP:192.168.178.43
[2020-03-04 01:50:23][0] VRAM used/free/max:0Kb/24Gb/24Gb Out-of-core used:0Kb RAM used:12.446Gb total:127.871Gb OpenGL free/total:0/0
[2020-03-04 01:50:23][1] Device:0 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:39
[2020-03-04 01:50:23][1] Device:1 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:44
[2020-03-04 01:50:23][1] setInteractive(1)[OK] [2020-03-04 01:50:23][1] readPrmsFrScn(1)
[2020-03-04 01:50:23][1] processRegions()
[2020-03-04 01:50:23][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:0.719ms. [OK]
[2020-03-04 01:50:23][1] setExportStatus(st=9, flg=0, thr=0)
[2020-03-04 01:50:23][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:0.405ms. [OK]
[2020-03-04 01:50:24][1] Daemon listener -> slave0: RENDERSLAVE state:5 IP:192.168.178.43
[2020-03-04 01:50:25][1] <markMaterials>
[2020-03-04 01:50:25][1] resetOrbxRootGraphs()
[2020-03-04 01:50:25][1] readPrmsFrScn(0)
[2020-03-04 01:50:25][1] readPrmsFrScn(1)
[2020-03-04 01:50:25][1] readPrmsBC 11111[2020-03-04 01:51:12][0] restoreDeviceStates status:2
[2020-03-04 01:51:12][0] setDevicesActivity rDevices:01 nDevices:01
[2020-03-04 01:51:12][0] save
[2020-03-04 01:51:12][0] AllDevicesOff
[2020-03-04 01:51:14][0] AllDevicesOff
[2020-03-04 01:51:15][0] AllDevicesOff
[2020-03-04 01:51:20][0] AllDevicesOff
[2020-03-04 01:51:21][0] AllDevicesOff
[2020-03-04 01:51:23][0] AllDevicesOff
[2020-03-04 01:51:24][0] AllDevicesOff
rclassenphoto
I have found that if there are many Octane materials in a .c4d file, octane gets stuck with c4d. If I delete all the unused materials and i only have the used materials in the scene, octane renders normally and quickly. But i i use the c4d files 3 weeks with the same amount of unesd material without any problem. After the new windows update the plugin made this problems. thats strange...
But, that cannot be the solution that I have to delete materials that are not used from the c4d file. It may also be that I need several materials.
And i now make a nother test with a different scene, the Octane Plugin dont start to render, without a error message it freze.
Return to “Releases”
