Changes of 2020.1-XB3-R2 - adding new quad/sphere light primitives by using "use primitives" in Light Tag
How to use this feature?
Octane Area Light Tag - Use Primitives(On) -- Nothing Happened.
Cinema 4D version 2020.1-XB3-R2 (EXPERIMENTAL) 12.02.2020
- eyeonestudio
- Contact:
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
What does not happen? It uses light primitives and makes render with less noise on first bounces of rays. Read standalone release notes for thateyeonestudio wrote:Changes of 2020.1-XB3-R2 - adding new quad/sphere light primitives by using "use primitives" in Light Tag
- eyeonestudio
- Contact:
Thanks for the information.aoktar wrote:What does not happen? It uses light primitives and makes render with less noise on first bounces of rays. Read standalone release notes for thateyeonestudio wrote:Changes of 2020.1-XB3-R2 - adding new quad/sphere light primitives by using "use primitives" in Light Tag
I found that.
OCIO is coming shortly in a future update to compliment the 2020.1 ACES support now in the core.nscr wrote:Is there OCIO or color management capable of viewing ACES in this release? Can't seem to find it.
it's working but not with "texture displacements". Try vertex displacements.BadBilly wrote:When are we going to see DIsplacement Mixer work?
Or at very least a mix material/ multiply/ add node that works with displacement?
with subdivision, I am getting ok results. But flexiblity here is good.aoktar wrote:it's working but not with "texture displacements". Try vertex displacements.BadBilly wrote:When are we going to see DIsplacement Mixer work?
Found another work-around with bake texture node.
- ArtUnleashedCanada
- Silverwing
- Contact:
I have Octane 2020.1_XB3-R2 running on C4D R 21.207. All the icons are there.ArtUnleashedCanada wrote:Hi there!
Running into a slight issue. I hjave Cinema 4D R21.207 and this version of octane render plugin has all the graphics for the buttons greyed out and looking weird. Works fine in r19 and r20.
Might be you accidentally deleted your "res" folder containing the icons when transferring the plugin?
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
