Hi all,
This is first and QUICK build of the plugin with EXPERIMENTAL 2020.1-XB3 SDK. Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1 XB3.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1-XB3-R2
- fix: missing deepExr saving for frames before last one
- adding new quad/sphere light primitives by using "use primitives" in Light Tag
- fix: embedded gui grab on unvisible parameters while drag
- fix a crash on oslCamera if octane is not activated
- wrong parameter assignment on universalCamera, for "pixel aspect ratio"
- support relative filenames in 'orbx loader' object
- Fix: ImageTiles filename problem
- Added ability to hide specific object layers from being evaluated by dirt.
Standalone changes of 2020.1-XB3
Fixed 100% transparent object casting shadow on a SSS material.
Fixed issue causing dirt to work just with the bottom level material when using composite materials.
Fixed issue causing some scenes using autofocus with RTX to miss some geometry.
Fixed GPU illegal memory access increasing shutter time from zero when using RTX.
Fixed network rendering when the master runs on OSX and uses either Windows or Linux slaves.
Fixed GPU invalid memory access when using auto-bumpmap with RTX geometry.
Fixed issue causing geometry to disappear when using a baking camera after switching render targets.
Fixed albedo for hair when the intersected primitive is not a hair primitive.
Fixed potential cause for artefacts in pixels which rays would be coplanar to quad primitives.
Fixed FBX export crash when the scene contains only hair or sphere primitives and no polygons.
Fixed issue in the way memory usage was tracked showing it continuously increasing.
Fixed issue with auto bump map which was not working properly on the universal material layers.
Fixed issue in auto bump map's plane size calculation which was causing wrong results.
Fixed issue that was causing geometry to disappear when using a displacement texture with zero height.
Fixed scenario in which auto bump would produce results hardly noticeable.
Fixed crash when using some OSL shaders including some OSL geometry.
Fixed issue causing full rebuilds after updating scatter nodes.
Fixed incorrect light sampling when using a a mix of RTX primitives and other primitive types.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Cinema 4D version 2020.1-XB3-R2 (EXPERIMENTAL) 12.02.2020
What does it here? I don't knowhow to add that. Probably it's not accesable by pluginsVVG wrote:Thanks,
Can you add here octane universal mat?
- eyeonestudio
- Contact:
Thanks for the Quick Release XB3....
C4D R2025 / Win11 / AMD TR WX Series / 256Gb RAM / RTX3090 / 100GbE
Ok it's possible with latest R21 build. Added but default is octane type. There's a lot of ways for fast material creations in plugin.VVG wrote:aoktar wrote:What does it here? I don't knowhow to add that. Probably it's not accesable by pluginsVVG wrote:Thanks,
i know, but Double click (as default) can be useful too.aoktar wrote:There's a lot of ways for fast material creations in plugin.
thanks!
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
It's last parameter but seems as wrongly named. I'll fix itStudio21 wrote:thx for your hard work ahmet.
Random Walk medium still misses the 'Bias' parameter
ty
G
