problem with file
tetrochuan
hi there,
i would really like to render the following scene using octane because of the dof effect which is so easiely achieved...
problem is however that i cant import the mesh into octane.... using latest octane and latest octane exporter pluging for c4d...
file comes from c4d r11.5 with vray light setup
i would be very pleased if anyone could have a look at the original file and the obj created... i tried to bring the obj in other apps, form z for example and it worked out!
well as the attach file of the forum wont work, here are 2 wikifortio links
http://www.wikifortio.com/743320/model.c4d
http://www.wikifortio.com/409867/model.obj
thank you.
ps not much of a monday morning ...=)
win7 ultimate 64bit | intel i7-3930k @ 42x100 | asus p9x79 pro | 32 gb ddr3-1600 | 3x780ti @ 1ghz | 2x asus proart pa246 24" | main hdd ocz vertex 4 | some mice keyboard and a wacom intuos4
blade_master7
Hi tetrochuan,
Sorry, I don't have C4D. I did import the obj file using 2.3 v5 without any problems. See attached image.
Hopefully someone with C4D can solve the plugin issue.
Cheers
Charles
tetrochuan
hm
ok thank you...
strange things
tetrochuan
could it be that my octane install is corrupt or im using false drivers?
but why would it crash after click on import mesh immediately?
No problems here with C4D 11.5 and Octane 1.23 v5 on mac ;)
I attach the .ocs .obj and .mtl
ciao beppe
Model.zip
(1.57 MiB) Downloaded 348 times
abstrax
tetrochuan wrote:could it be that my octane install is corrupt or im using false drivers?
That sounds like a driver problem. Which hardware and which driver are you using?
Cheers,
Marcus
tetrochuan
thanks for replys,
i will reinstall cuda 3.0 and the latest driver ... hopefully this works!
tetrochuan
after reinstalling octane, cuda and display drivers still wont work?!
what else could be the problem here?
acc24ex
tetrochuan wrote:after reinstalling octane, cuda and display drivers still wont work?!
nice model, runs smoothly, so the c4d scene is ok, your software is not, I have the 258.96 nvidia drivers, so check that and the cuda drivers
