UE4 Textures
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
theghalwash
hey this is more of a question. in ue4 texture editor when I change the max Texture resolution does this affect the resolution used in octane or not ?
ChrisHekman
At the moment it caps out at 2k. The cap is based on the unreal default max in game.
Ill check if I can make it match the unreal max in-game
theghalwash
ChrisHekman wrote:At the moment it caps out at 2k. The cap is based on the unreal default max in game.
that would cool for optimization .. thaaaaanks
EvolverInteractive
You can change the system ini files to increase the max resolution, and when you are using HDRI, your HDRI cube map will be much higher res also.
theghalwash
EvolverInteractive wrote:You can change the system ini files to increase the max resolution, and when you are using HDRI, your HDRI cube map will be much higher res also.
i was talking about reducing a texture res on the go to keep v-ram at a nice point
Return to “Unreal® Engine”
