Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
martinzip
Dear Ahmet
thanks a lot for the great work you do! I found a strange behaviour with connecting slaves.
When I connect them one by one they work altogether. When I have all of them running at once no one wants to connect with the master...
Strange...
Kind regards and cheers
Martin
System Macos 12.6 C4D R20
Silverwing wrote:With the latest 2019.1.5-R2 I get multible error messages when trying to make a Blend Material! / Composit Material.
It was a resource problem due to the missed keyword. Fixed the builds, thanks!
Silverwing
Thank you very much!
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
rclassenphoto
Hi, so i have some problem. If i have c4d files with "Texture" paths missing an the textures a Error to load the Octane Plugin crashes all time. You can only open a new file with no "error "paths" and than fire octane again. Let it open, open a the file with the lost "texture" paths and fix the paths. Then it works. But if you dont fix this missing path with a new file with no missing paths all files that you are open are getting a error. PLEASE fix this shit. I cost me so much time. THX
rclassenphoto wrote:Hi, so i have some problem. If i have c4d files with "Texture" paths missing an the textures a Error to load the Octane Plugin crashes all time. You can only open a new file with no "error "paths" and than fire octane again. Let it open, open a the file with the lost "texture" paths and fix the paths. Then it works. But if you dont fix this missing path with a new file with no missing paths all files that you are open are getting a error. PLEASE fix this shit. I cost me so much time. THX
Make some tests with disabled material and opengl previews. Is it still crashing?
shine71
Hi Ahmet!
Sorry to bother you.... have you any news about issues related to c4d tiles shader?
Till 2020 won't be ready I'm afraid I have to use 4.05 yet, if this issue can't be fixed...
Thanks for your work!
Cheers!
Turck
Hello there!
I also have the issue that Cinema 4D does not recognize my Octane 2019.1.5-R2 installation.
Standalone works fine. I have installed may iterations of the Octane plugin before, but can not get this one to work.
My previous working plugin was 2019.3.
C4D is up to date, Nvidia driver is 436.15.
Any ideas?
Hi Turck,
have you updated C4D to the latest version?
Please go to c4d menu Help/Check for updates.
ciao Beppe
Turck
I am on R21.022 (RC), no updates available. Nvidia driver is up to date now, too.
Is that the newest version of C4D?
Error Message
Error Message
Hi Turk,
latest R21 is R21.115.
@shine71:
please, remove the installed version, and download and install again v2019.1.5-R2.
Here it is working as expected with Image Tiles node.
ciao Beppe
Return to “Releases”
