Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
divasoft
Every time when i insert ColorCorrection node this way, cinema crashes. Do you have any idea what is the reason?
nVidia driver 441.66
video https://yadi.sk/i/5fsckTVFU4LCkA
scene https://yadi.sk/d/JfMLwHpJdatyYg
in addition, the change in material with displacement maps is still extremely unstable. I get cinema crashes about once every 5-10 minutes. Connecting nodes, editing a gradient node, drug node or editor’s node windows, editing values can cause crash at randome time.
handsomeninja
after almost a month of testing I can say this is one of the best/stable/complete versions we've had.
so thank you Ahmet!
I just wanna mention I had to disable multithread for materials while rendering sequences, or I'd - sometimes - get crashes after several frames.
handsomeninja wrote:after almost a month of testing I can say this is one of the best/stable/complete versions we've had.
so thank you Ahmet!
Thanks! 4.05/2019.1.5 or 2020.1xx have same plugin core. Difference is that used SDK and added implementations in plugin side. But core functionality stays same.
Problems mostly come from latest drivers and core. When people mention from crashes who should attach bugreport.zip/c4doctanelog.txt/scene and description for how it happens.
shine71
Hi Ahmet!
I took a quick look to 2020 new experimental you have just released and I saw that issue I reported about c4d tiling shader has been fixed. Could you include same fix in this one that is stable?
Thanks a lot for all your work!
Cheers
shine71 wrote:Hi Ahmet!
Cheers
New build is available now
shine71
Cheers
Downloaded and tested, it works!
You're the best, Ahmet!
Thanks a lot! :)
thanulee
Awesome! OSL displacement works ? In general volume displacement is working on this version? thanks
thanulee wrote:Awesome! OSL displacement works ? In general volume displacement is working on this version? thanks
No, I made a mistake on information. It's a part of 2020.1.
shine71
Good morning Ahmet! :)
Regarding c4d tiles shader I have to tell you that new release renders correctly previuosly done materials without the issues I met in the past, but each time you open a material or try to add same shader, c4d crashes.... :(
Could you take a look, please? :roll:
Thanks a lot!!!
Cheers
Silverwing
With the latest 2019.1.5-R2 I get multible error messages when trying to make a Blend Material! / Composit Material.
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Return to “Releases”
