OctaneRender 2020.1 LightWave Beta build 2020.1.0.1
Forums: OctaneRender 2020.1 LightWave Beta build 2020.1.0.1
Re: OctaneRender 2020.1 LightWave Beta build 2020.1.0.1
Postby juanjgon » Tue Jan 07, 2020 4:31 pm
juanjgon Tue Jan 07, 2020 4:31 pm
AndyM1969 wrote:Finally got it working but of course there are problems, volume node in environment is broken, regardless of settings it either has no effect at all or produces a completely black render.
There is a bug in the volume medium node while loading old scenes. The new "Lock Step Lengths" option should be enabled by default, but it is disabled and with wrong "Shadow Step Length" value, set to 0.0. Both issues will be fixed in the next build, but meanwhile if you enable the "Lock Step Lengths" option in all the volume medium nodes, the rendering should be fine.
Thanks for reporting this issue!
juanjgon
Postby ruuterdetuuter » Wed Jan 08, 2020 10:54 am
ruuterdetuuter Wed Jan 08, 2020 10:54 am
I've run a few comparison renders between the 2019 and the 2020 version. And without using the RTX version al my renders turn out to be around 10% slower with the 2020 version compared to the 2019 version.
My configuration while testing was: 1x GTX 1080 TI Xtreme + 1x RTX 2080 TI OC
Do any of you experience this? And if not, what could be my problem? All drivers updated to the last including the Windows update.
Thanks and BTW thanks for al the development work Juanigon!
ruuterdetuuter
Postby Carlos3D » Sat Jan 11, 2020 1:44 am
Carlos3D Sat Jan 11, 2020 1:44 am
juanjgon wrote:
Carlos3D wrote:Hi Juanjo.
Is there any possibility that the Region limit of this window will work with Denoiser?
Without this I am always required to render the whole frame or all scene in an animation.
Thanks.
I'm not sure if this is even possible in Octane, but in any case be aware that the AI denoising works using the whole frame as a reference ... denoising a render region will not match the initial denoising for sure, producing flickering in the animated sequences.
Thanks for replying but unfortunately I didn't realize what you mean! ...
Carlos3D
Postby Carlos3D » Tue Jan 14, 2020 11:04 am
Carlos3D Tue Jan 14, 2020 11:04 am
When I map a video it does not appear in my animated render.
The question is: Is it possible to map videos on Octane?
Thanks.
Carlos3D
Postby Lewis » Tue Jan 14, 2020 11:10 am
Lewis Tue Jan 14, 2020 11:10 am
Carlos3D wrote:When I map a video it does not appear in my animated render.
Thanks.
It should work (alhough it's better to have frames in general) just be sure you have Update materials ON
http://prntscr.com/qnh8ej
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
WS Dual Xeon E5-2698v4, 128GB RAM, Win10, 4 * RTX 2080Ti
RS1 i7 9800X, 64GB RAM, Win10, 3 * GTX 1080Ti
RS2 i7 6850K, 64GB RAM, Win10, 3 * GTX 1080Ti
Lewis
Postby Carlos3D » Tue Jan 14, 2020 12:40 pm
Carlos3D Tue Jan 14, 2020 12:40 pm
Thanks.
I already did it but unfortunately it doesn't work here on my Octane.
Carlos3D
Postby Lewis » Tue Jan 14, 2020 12:55 pm
Lewis Tue Jan 14, 2020 12:55 pm
Thanks.
F9/F10 or IPR ? for IPR you need to have material button in IPR also.
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Postby juanjgon » Tue Jan 14, 2020 2:17 pm
juanjgon Tue Jan 14, 2020 2:17 pm
Hmm, I think that Octane doesn't support animated textures from video files. You need to convert them to image sequences and load the sequence from the LightWave image editor.
juanjgon
Postby Carlos3D » Tue Jan 14, 2020 3:13 pm
Carlos3D Tue Jan 14, 2020 3:13 pm
juanjgon wrote:Hmm, I think that Octane doesn't support animated textures from video files. You need to convert them to image sequences and load the sequence from the LightWave image editor.
Thank you very much Juanjo Ill do that right now.
Carlos3D
Postby Carlos3D » Tue Jan 14, 2020 3:24 pm
Carlos3D Tue Jan 14, 2020 3:24 pm
Works perfectly, thank you very much Juanjo and Lewis...
Never video format only sequence.
Carlos3D
PreviousNext
Return to Lightwave 3D
Users browsing this forum: Google [Bot] and 2 guests
Fri Apr 10, 2020 8:46 am [ UTC ]
