CHECK it! Then it will use OSL script for C4D shaders.HTK421 wrote:Im a bit confused,... do we CHECK or UNCHECK this box to use C4D shaders?"Activate it from Settings/c4d shaders->use osl for c4d noise/gradient"
The wording suggests that when the box is checked we are using OSL instead of C4D
Also, do we CHECK or UNCHECK 'Enable C4D Shader Baking ?
Having this checked suggests that we are still baking noises instead of making them procedural Thanks
Cinema 4D version 2020.1-XB2-R2 (EXPERIMENTAL) 10.01.2020
It's not available in C4D plugin and it's working with some scripted nodegraph in standalone. It's not implemented because of some hardnesses and having problems to able to do that. It will be available when I/we can solve that.VVG wrote:I do not ask stupid questions every 5 minutes. I've been here too long.aoktar wrote:It's a truth. Also I cannot work if I try to spend much time on every questions or problems. Thanks for explanations!frankmci wrote: This is an XB build, undergoing rapid development by very busy people. Not every question will be answered, or should be answered. This is triage. It's a bit different with an officially stable release, but for this thread, cool your freakin' heels, dude.
Who else do I need to ask about the announced new features 2020.1 if even core dev are silent how they work?
Are they just gone (Vectron Volumes)?
Well, that answer is enough.aoktar wrote: It's not available in C4D plugin and it's working with some scripted nodegraph in standalone. It's not implemented because of some hardnesses and having problems to able to do that. It will be available when I/we can solve that.
And there was no need to create problems with my behavior.
We, as users, should be aware of what is planned, what is already at the moment in integration.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
- LOVEXMEDIA
VVG wrote:Well, that answer is enough.aoktar wrote: It's not available in C4D plugin and it's working with some scripted nodegraph in standalone. It's not implemented because of some hardnesses and having problems to able to do that. It will be available when I/we can solve that.
Luckily there is a forum that has the latest updates and road-maps for us, users, to read at our leisure. Our money pays for the use of the program not the rights to instant recognition. I get anxious too so I feel your energy but these peeps just wake up and do work like the rest of us. Try and show some empathy and see the big picture. I am just as excited for the stable release but it's all in time.
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
Yes you do have your answer. Be patient. Its a beta test (look at the heading - EXPERIMENTAL).VVG wrote:aoktar wrote:VVG wrote:ok
viewtopic.php?p=375244#p375244
If you don’t have an answer, say so. I have no answer to this question yet
Being rude to the developers isnt going to get any favors done.
BadBilly wrote: Yes you do have your answer. Be patient. Its a beta test (look at the heading - EXPERIMENTAL).
Do you want to explain to me what and how it works on this forum? )) Good luck and optimism to you.
- eyeonestudio
- Contact:
Did the function of the ALT key change in the node editor in R20?
R19
LBM + Click Node - Node Option
MMB - Pan
R20
LMB MMB - Pan
Alt+Click Node - Node Option
R21
MMB - Pan
R19
MMB - Pan
R20
LMB MMB - Pan
R21
MMB - Pan
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
No, just build same code for different versions. It's working as should be on meeyeonestudio wrote:Did the function of the ALT key change in the node editor in R20?
R19
MMB - Pan
R20
LMB MMB - Pan
R21
MMB - Pan
- eyeonestudio
- Contact:
Ok. Thanks. I will check again.aoktar wrote:No, just build same code for different versions. It's working as should be on meeyeonestudio wrote:Did the function of the ALT key change in the node editor in R20?
R19
MMB - Pan
R20
LMB MMB - Pan
R21
MMB - Pan
There is still bug with cloner related to "one instance". Last time cloner didn't displayed first instance. Now cloner doesn't display instance if it count is set to one
