Hi guys ,
I am trying to load a simple orbx file inside houdini with the ORBX SOP, but it doesn't display anything at render time.
The orbx works perfectly in standalone, but i can't make it work in houdini, i might be doing something wrong but i don't know what ?
I use houdini Indie 17.5 with Octane 2018.1.3 on windows.
Cheers
E
How to use Octane ORBX SOP ?
Have you tried to import the .orbx file once it has a geometry output or a render target node as the final root node?
- 2019-09-23 21_48_55-_C__Users_juanj_Downloads_trex_08.orbx - OctaneRender Enterprise 2019.2 XB1.jpg (10.81 KiB) Viewed 6394 times
- 2019-09-23 21_48_41-_C__Users_juanj_Downloads_trex_08.orbx - OctaneRender Enterprise 2019.2 XB1.jpg (7.68 KiB) Viewed 6394 times
Thanks for your answer Juanjo,
I have try both of your solution but none of them work.
I have the following error message : Are you sure that it is not related to an Indie License restriction that doesn't allow orbx access ?
I have attach the orbx scene. It does work smoothly in standalone but not with the Orbx SOP. Cheers
E
E
