Constant Render Refresh
Moderator: ChrisHekman
- EvolverInteractive
When the Color Correction Node is plugged into the Roughness, the render just constantly restarts 1 sample then again never resolving until you remove the color correction node from only the roughness on a universal material
- ChrisHekman
Like this?
This works for on my end. What other setup do you use?
Could you share the material with me?
Yes,
I don't have the color correction node in, I am in the middle of a project right now. I think because there was no roughness data to pass on. My fault. The Datasmith actor thing is true, too.
1. Probably because I looked at the parent material and the model was on a SPEC work flow so Roughness wasn't even piped in
2. It was and Datasmith Actor selected and that causes the same thing.
Soo much fun, but if you need anything from me, I can do videos instead of post also
