Hi
I am using Houdini 18.0.287 with Octane 2019.1.5 and I am having troubles updating the IPR automatically after modifying or adding a geometry. It simply doesn't change on the IPR viewport and I have to keep pressing the Reload Button to be able to see it any change and it takes a long time to do it.
Is there any check box that I am missing? I am attaching a screen grab to illustrate my problem.
Any help would be great.
IPR Update.
- snakeboxmedia
in the IPR you have to turn on full reload, then it will but remember to also turn on full scene reload in the scene update tab in your render settings. This is normal and needed for any geometry changes.
The IPR window doesn't support hotkeys yet, but several of its functions are also available as Hscript commands that probably could be mapped on the Houdini side. If you type "Octane" in the textport, you could get the list of all available Octane Hscript commands.ginodauri wrote:One question about ipr.
Does is have some hotkeys related to it , like hotkey for reload , alpha , etc...
